3vze doing rod bearings
Old 12-08-2013, 07:07 AM
goinggoat's Avatar
3vze doing rod bearings, do you recommend oil pump at same time?(100k miles)
Old 12-08-2013, 07:13 AM
jb451's Avatar
If the motor is out of the vehicle (and i can't imagine doing bearings with it not…yuck.) i'd say might as well if the cash is there… Make sure you get an OEM pump though, thats not something i'd want to do twice.
Are the bearings shot? Why are you doing them?
Old 12-08-2013, 07:38 AM
goinggoat's Avatar
The engine is in the truck. I developed a rod knock inbetween Kingman & Flagstaff (climbing hills) I limped back to Kingman overheating and am now stuck in a motel. Please help
Old 12-08-2013, 07:43 AM
JasonYota's Avatar
Welcome from Alabama
If your truck is overheating also you may have blew a head gasket
Old 12-08-2013, 07:48 AM
goinggoat's Avatar
Ok did the spark plug wire test,knock is #2 cylinder what do you recommend?
Old 12-08-2013, 07:58 AM
JasonYota's Avatar
What is the spark plug wire test?
Drive it till it blows or rebuild it or swap it
Old 12-08-2013, 08:33 AM
jb451's Avatar
x2, get it back to the house first, if it has a rod knock and overheating, the motor is already going to need a full overhaul. Might as well make it back to the house if you can.
Old 12-08-2013, 09:33 AM
goinggoat's Avatar
Can't do it. moving from las vegas to florida. changed the thermostat not overheating now but the damage is done
bigjstang
08-25-2021 12:41 AM
4x4-runner
12-27-2016 01:58 PM
Iceman4193
08-28-2015 08:43 PM
JAmdor3
08-11-2015 10:53 AM
Shaun Crystal Gomban
08-02-2015 08:00 PM
Quick Reply: 3vze doing rod bearings
