3VZE coolant leak - pass side
Old 01-13-2016, 11:24 AM
az4x4runner's Avatar
I am pretty familiar with this engine, and I've searched and searched, but can't seem to pinpoint this leak without tearing the AC compressor and everything around it out.
I have a leak somewhere on the passenger side above the AC compressor. Coolant actually drips off the compressor and on to steering linkage.
I can see the freeze plugs through the wheel well, they're dry.
It's just a little trickle, mostly after cold start and quickly shut off, driving me nuts for months now, but no visibility behind the compressor. Any ideas?
Old 01-13-2016, 12:00 PM
I just pulled the tire off so I could really get in there and look, all dry, all round front freeze plug, dry. I can see where the hydraulic timing tensioner bolts up, dry. Wtf...
Old 01-13-2016, 12:39 PM
MudHippy's Avatar
And it's not leaking from the obvious spot right above the AC compressor? As in the coolant drain plug for the RH side of the block.
Old 01-13-2016, 12:40 PM
Correct. The drain plug is behind motor mount, between the two freeze plugs, right?
Old 01-13-2016, 12:42 PM
Actually the drain plug I see, if it is indeed a drain plug, is very close to the front freeze plug. Got a pic of the right side of a 3VZE?
Old 01-13-2016, 12:49 PM
MudHippy's Avatar
That's the one. 14mm hex head brass plug.
EDIT: I found a good pic. It's a 5VZ-FE .But it's in the same location as a 3VZ-E.
LucasF249
02-23-2016 12:12 PM
-City Slicker
01-05-2016 06:54 AM
80seriesftw
11-22-2015 07:50 PM
Mattluke1
11-02-2015 07:08 PM
anndel
10-24-2015 11:34 PM
Quick Reply: 3VZE coolant leak - pass side
