3vze catalytic converter help
Old 10-28-2011, 07:09 PM
superswamper003's Avatar
Hi my 1994 toyota pickup 3.slow needs a cat. The dealership says that i need a special number or something for the cat i need to get. But wont any 3.slow cat work for my truck? Thanks
Old 10-28-2011, 07:46 PM
HawkStrong16's Avatar
Remove it, gut it, weld it back on.
Or go to a autoparts store, not a stealership. and see what they say.. You could always try putting a high flow cat on from magnaflow
Good luck!
Old 10-28-2011, 09:23 PM
808-3VZE's Avatar
I removed mine and put a straight pipe in there. In Hawaiib we are lucky no smog check!
Old 10-28-2011, 10:47 PM
wyoming9's Avatar
Smile
The way the Toyota Factory parts computer is set up it goes off your VIN and tells them you need Toyota part # for your vehicle.
Go to any web sites that sell them check the part # for your vehicle see if they have any foot notes saying except year ** or something like that.
Should not be all that uncommon.
Just try and stay legal for what emissions laws your state has
Old 10-28-2011, 11:10 PM
BMcEL's Avatar
I'm running a Magnaflow high flow cat on my '90 and I love it:
http://www.summitracing.com/parts/MPE-23884/
Old 10-29-2011, 06:22 AM
Hm yeah i was looking at some high flow magnaflows and thats what ill probably get one of those. Im in Arizona so idk how strict the laws are down here
Old 10-29-2011, 08:58 AM
BMcEL's Avatar
The one I linked to above meets federal requirements. They have one that meets CA requirements but it's like $250.
There are no emissions checks where I live but I hated the sound of the exhaust without a cat.
Old 10-29-2011, 09:13 AM
Waylayer's Avatar
i got one out of summit racing for like $50 and with after market cheapo muffler and some straight pipe & adapters ect. welded together a new exhaust for about $200. could have clamped it but truck takes a beating and stumps would have ripped it apart.
Old 10-29-2011, 11:56 AM
hmm does that come with the sensor? Because my truck has a CEL on
Old 10-29-2011, 03:01 PM
smogman's Avatar
being outside of cali you can weld on any old cat. Summit cheapo is the best bet. Most muffler shops can weld a bung on for the temp sensor.
Cali has to have approved converters for the smog check or you will fail
Old 10-29-2011, 05:37 PM
oh ok so no cat comes with the sensor? If not, how much would a sensor be?
Old 10-29-2011, 05:46 PM
BMcEL's Avatar
Don't use anything but Denso for the O2 sensor. Great website for cheap genuine Denso products:
http://www.densoproducts.com
Old 10-29-2011, 06:55 PM
Thanks man, umm what does SRW and DRW mean under the application?
Old 10-29-2011, 07:16 PM
BMcEL's Avatar
Single or dual rear wheels.
Old 10-29-2011, 07:17 PM
Thanks for the help!
kawazx636
10-06-2021 03:03 PM
Kamaloha
10-16-2015 05:13 PM
alexcarey
10-14-2015 06:05 PM
Cycles
09-29-2015 06:37 AM
Scotttekoch
09-28-2015 10:30 PM
Quick Reply: 3vze catalytic converter help
