3vze carnage
3vze carnage
Thought you guys might find this interesting. Was just driving along, heard a clunk, and the motor stalled.
As far as we know something caused the driver side cam to seize up (thrown rod, maybe?), the pin sheared, and the timing belt tightened the cam bolt until it sheared off.
Worst luck ever :mad3:
It still turns over at the crank.
Clicky for fullsize:
If you want to get rid of it, go for it, but a 3.4 swap will make it a whole new rig. Personally, I'd rather fix up what I got than buy something else with a whole new set of problems.
I just graduated high school and don't have the time/money to do a 3.4 swap. I need something more economical anyway
personally I would rather do a 1uz-fe motor swap then the 22re swap. its a little more work to fit the motor but you get a but load of power and an upgrade transmission (if you want it)
for that matter... if you have access to a local wrecking yard.. keep your eye out for a 3uz-fe. it would hook up to a tundra transmission with no adapters needed.
there is lots of options other then a little 4 cylinder that will get 20mpg + when hooked up under the hood of a 4runner. if you do decide to rebuild, look into the DOHC option for the engine. it uses a 3.4 intake to make it work and camry heads off of the 3.0 v6. it makes more power then the 3.4 with a 3.0 displacement.
dont get me wrong.. the 22re is a great little motor that powers a lot of toyota's everywhere they need... just not for me. I like being able to tow big trailers with lots of toys.
no matter what you decide to do... make sure its gonna last and do it right the first time.
I was under the impression no one ever really finished this. Do you have more info?
What would be really interesting is if we knew exactly how that happened.
BUT, for all we know...you broke the bolt overtightening it...or any other manner of setting the scene to make it look as if something like what you describe may actually have occured. What I'm getting at is...where's the carnage? I'm not seeing any. I might be seeing where the knock pin for the camshaft timing pulley is sheared off inside the hole. Or I might be seeing that it isn't, which would make your story a lot harder to believe. The pic isn't that great though...so I dunno...
i think you just have a broken cam bolt. usually if a bottom end takes a dump, the belt and timing arent affected. i would think even in such an event, the belt would shred or break long before that cam bolt.
Green antifreeze? Mine has Toyota Red in it. Anyway, find out whats wrong with it would be my suggestion... No reason to do away with the 4runner over such a seemingly small fix.
Looks like the bolt stress fractured possibly from being overtorqued at install and time just killed it. I can see where once the cam bolt was going the timing belt caused the pin to shear. Being a non-interference enging the head may be very well ok....the cam may have been no so lucky.
I would LOVE to do a motor swap and keep the 4runner, but it's just not a viable option.
That's what I think happened, I don't know. I'm not a mechanic, but I do have some experience working as shop ho in a 4x4 shop. I haven't touched it except for tearing it down to see what was wrong with it.
In other words...you're just not as interested in finding out what really happened as we are. But, if you could tear it down that far, you could just as easily tear it down far enough to figure out what really caused it. It's just nuts and bolts.
It's like watching the first half of a movie...and never seeing the last half to find out how it ends.
