3vz oil light
Old 05-03-2014, 09:05 PM
dude93's Avatar
3vz oil light
I have a 93 5spd 4x pickup with a 3vz and i am getting worried about the oil light. it flickers on startup and comes on at about 1500 rpm under accel and comes on bright on decel. People have told me is could be the pump, bearings, or sending unit. please help
Old 05-04-2014, 09:18 PM
Punchy's Avatar
Sounds like the oil wire is frayed and shorting to the head or alternator bracket.
Follow the wire from the pressure switch wire up and you will find a junction plug.
From there it runs up and into the plastic shroud next to the distributor.
Other possibility is the switch has gone bad.
Old 05-07-2014, 07:18 PM
dude93's Avatar
Is the pressure switch by the oil filter?
Old 05-08-2014, 10:07 PM
Punchy's Avatar
Yes
Is this a SR5 gauge w tach?
smthwsn357
12-04-2023 02:08 AM
09-04-2015 09:27 AM
Odin
07-15-2015 09:28 PM
Sandman
07-14-2015 12:36 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: 3vz oil light
