3vz failing smog no ac and code 51.
Old 08-17-2011, 02:01 PM
drkblu4runner's Avatar
when i have the diagnostic connectors jumped and truck is idling it rapidly blinks like normal, however if i give it gas it gives me a code 51 and as soon as it is back at idl it goes away. tested the idl and e2 connectors on the tps and they are working. hoping that its the problen with the smog or the ac
Old 08-17-2011, 05:33 PM
TNRabbit's Avatar
You don't check for codes with the engine running. Key ON after TE1 & E1 jumped.
Colde 51, IIRC is knock sensor. That would put your timing at 0 degrees BTDC.
Old 08-17-2011, 07:37 PM
so thats normal?
Code 51 AC signal on; DL contact off (in trany shifter with diagnostic connector jumped)
NOT>Code 52, 53 and 55 Knock sensor fault
Old 08-17-2011, 10:43 PM
Anyone els have this?
Old 08-18-2011, 02:21 PM
anyone? i have already failed smog 3 times
Old 08-18-2011, 03:16 PM
check vid out.... i just tried another tps without any change.. http://youtu.be/J3f56LhEdEU
Old 08-18-2011, 04:55 PM
TNRabbit's Avatar
You DO know how to adjust the TPS, right?
Old 08-18-2011, 05:06 PM
Yes. I have 3 4runners, 2 of them are 3.slows..the other 3.slow does not get the code 51 btw. I appreciate any help
jmoua
03-29-2023 03:42 PM
accuracy
08-30-2015 09:47 PM
JustToynAround
08-19-2015 11:46 AM
accuracy
08-04-2015 08:05 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: 3vz failing smog no ac and code 51.
