3vz afm adjustment question..
Old 08-09-2013, 04:50 PM
Borg18's Avatar
I've read a few threads on adjusting the wheel in the afm and also referenced other write ups on other sites ..my question is, some people say turn counter clockwise for lean and i found a couple of pics that have arrows pointing clockwise for lean...which way is lean?
Old 08-09-2013, 04:55 PM
a51young's Avatar
I turned mine counter clockwise and saw an increase in mpg, also advanced my timing to 15*, not sure if that did anything or not though haha. Also removed my efi fuse for a few minutes, not sure if that is necessary or not though either but I figured it wouldn't hurt anything
Old 08-09-2013, 04:58 PM
Borg18's Avatar
This is a pic i found from one of the write ups
Old 08-09-2013, 05:02 PM
a51young's Avatar
I think that might have been the one I did actually, mixed up the orientation of the teeth in my head.
This one here
http://www.customtacos.com/forum/showthread.php?t=56229
Old 08-09-2013, 05:06 PM
Borg18's Avatar
Lol...awesome, the perfect person to clarify
..ok so it is counter clockwise then? How many clicks would be a saFe number?
Old 08-09-2013, 05:34 PM
a51young's Avatar
haha, yeah it depends on how you count... I used that pic above when doing mine, 2 clicks lean. Some people do 3 or more. It probably depends on a few things in terms of safe, as that is fairly relative. 2 or 3 is probably safe, adjust idle and see how the next few tanks work.
Also put a mark at the stock location for reference.
should be moving the teeth clockwise right? probably use 2 flat heads or something to do it, that's what I did
Old 08-09-2013, 09:31 PM
Inu
Inu's Avatar
Tighten spring leans it. Im at 14 clockwise/ lean but its not exactly stock or normal either.
Old 08-10-2013, 02:57 AM
Borg18's Avatar
what kinda a mods do u have that allow u to lean it out so much? if u dont mind me asking
Old 08-10-2013, 08:06 AM
Inu
Inu's Avatar
Cut off muffler, rebuilt engine, cams, and oversize injectors. Before the injectors it would lean out at hi rpm due to afm maxing out.
zytra
01-24-2019 03:16 PM
the_supernerd
10-01-2015 09:20 PM
Rerun
3.4 Swaps
10-01-2015 12:24 PM
dbollier123
09-29-2015 05:23 PM
toyotasaurus
09-24-2015 03:30 PM
Quick Reply: 3vz afm adjustment question..
