383 chevy stroker
383 chevy stroker
Hi Guy's i'm wanting to put a 383 stroker in my 92 4runner rig. Where do i find an adapter kit to bolt the stroker to? what do i need to put the stroker in? and what would be the best gear set for the stroker?
Google search for 4runner v8 swap. The 383 is a small block, same external size as the 350.
Contact advance adapters, they have everything you need.
You'll break stock driveline, regardless of gear ratio.
Yeah I wouldnt go building any SBC with over 300ft/lb's of torque. If you have the power your gonna hit the gas and thats when you break rings and axles. You can easily achieve a 327 or 350 with 250 torque and 220 hp with an awsome torque range and not worry about breaking anything with a v6 toyota driveline. A well built 383 is too much for a dana 44 let alone a stock Toy axle.
JookUpVandetti
09-30-2015 08:58 AM
1965chevy
09-20-2015 07:33 PM
JookUpVandetti
09-17-2015 09:25 PM
