33x9.5 on 7.5 Rims?
Old 09-15-2009, 11:53 AM
RustBucket's Avatar
33x9.5 on 7.5 Rims?
Not to belabor this topic too much and certainly not to bring up the old "wide vs. skinny debate," but I plan on buying a set of 33x9.5x15 BFG AT's soon and would like the collective wheeling experience regarding these mounted to 7.5" rims.
I would like to be able to air down to 15-20 psi without worrying about popping a bead. Tire rack claims that the 9.5" wide tires are acceptable for the 6.5-8.5 rim size range.
Is there a significant difference in aired-down reliability between the 9.5" width and the 10.5" width?
Old 09-15-2009, 01:18 PM
tc
tc's Avatar
2" difference you should be OK.
I ran 34x9.50 swampers on 8" rims, and that SUCKED. I was constantly getting damage to the rim of the wheel, and couldn't air down much.
AxleIke runs those on stock 7" rims and doesn't have too much trouble til he gets down to like 10 or 12 psi.
Old 09-15-2009, 01:32 PM
kawasakimoto_7's Avatar
yeah.. thatll be fine. but if you really are worried go to an actually tire shop and have them test it out for you.. as in dropping the air pressure from what you have it when you are just normally driving..
Old 09-15-2009, 05:10 PM
RustBucket's Avatar
Great, thanks guys!
TheBFA
02-15-2020 06:55 AM
1uzRunner
63
11-10-2018 03:58 PM
Cycles
09-29-2015 06:37 AM
Bill McBride
09-20-2015 02:51 PM
AkitaDog
09-03-2015 09:01 PM
Quick Reply: 33x9.5 on 7.5 Rims?
