| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
33x10.5 with 5.71 Gears?
__________________
Christopher ____________________________________________ 94 4Runner 3vze, ISR, Auto Downey 2" Coils 1 1/2" BJ Spacers Doetsch Tech MV-12s OME Steering Stabilizer 31 x 10.50 All-Terrain T/A's Last edited by creeve4; 04-23-2007 at 01:38 PM. |
#2 (permalink) |
5.29 gears would better suit 33" tires with the v6 auto.
__________________
91 Pickup - xcab - 5sp - 3.0 - SR5 - 4x4 - 250k |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs | Diff breather mod| Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |idler arm brace|hella E-codes| Marlin armor |SS IFS brace | %100 Amsoil synthetic http://www.cardomain.com/ride/2572486 |
#3 (permalink) |
yep, 5.29s would put you close to stock rpms with 33s.
#4 (permalink) |
I've never driven a 3.0 automatic, but I think that the gearing for the auto, that most reccomend would be 4.88s for 31's, 5.29s for 33's and so on...
The auto tranny behind the 3.slow is a 4speed btw.
__________________
87 4runner 4x4 SR5 22RE ARB Bull Bar, 31X10.50 Mastercraft M/T's, Stock 4.10 Gears, Flowmaster Muffler, LCE Header AISIN Manual Hubs, Marlin Crawler Sliders 190XXX miles Last edited by bob200587; 04-23-2007 at 02:28 PM. |
#5 (permalink) |
Yep, 5.71's if you want to be able to hold the overdrive.
Factory was undergeared (won't hold the OD) with 4.88's and 31's, so you want to be higher RPM's than stock.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
#6 (permalink) |
I would suggest undergearing as well to compensate for the added drag of the larger tires. RPM's are already too low with 4.88's and 31's as mentioned, go 5.71.
Frank
__________________
1994 4runner, 3.0, auto, 5.71's, Truetrac (rear), 33's, BJ spacers, Coil spacers, air shocks, D-ring anchors, 4Crawler F/R swaybar discos, Marlin rear bumper. www.sdori.com |
#7 (permalink) |
Thank you very much for the advice. I was leaning towards the 5.71's and that is what I will go with.
__________________
Christopher ____________________________________________ 94 4Runner 3vze, ISR, Auto Downey 2" Coils 1 1/2" BJ Spacers Doetsch Tech MV-12s OME Steering Stabilizer 31 x 10.50 All-Terrain T/A's |
#8 (permalink) |
Note that the lower the gear ratio, the more critical the setup. You want to have them done by someone who does it every day - not thinks they can handle it. Check out www.gearinstalls.com - hell, print it out and take it with you!
__________________
#9 (permalink) |
With the auto, 33's, and 5.71's you will be at 3200 rpm at 75mph, which isnt to bad... 5.29's will only yield you 2965, which isnt much different that OEM, so go with the 5.71's. The only issue I would see is that if you kick out of OD at 75 you will be at 4500+ rpms...
__________________
-John '05 Dodge 3500 SRW 4x4 SLT 5.9 Cummins QC LB NV5600 2003 SR5 4Runner, V6 4WD. 1" cornfed lift Previous Toyota's '92 Red Truck NALA Speed doesn't kill, its the sudden stop that hurts. |
#10 (permalink) |
Update on this setup: I'm now running 5.71's, 33x10.50's, auto. It is badass. It should have came from the factory this way. It is in the power band all the time, and completely woke this truck up. The highway is a cakewalk doing 75... and It hasnt bumped out of OD yet, just pulls up hills like they are no problem.
I'm still on my first tank of gas... but i'll update mileage wise. |
#11 (permalink) | |
Quote:
BtW Auburn, we need to go wheeling man. [end hijack]
__________________
-Brandon 1988 4Runner SR5 4x4 V6 5 Speed Swap (R150F)~SDORI 1.5" BJ Spacers~Downey 26MM TBs~Downey 3" Springs~Downey Shackles~PC ES3000s~PC ES2000 SS~Motive Gear 5.29s~Rear Detroit~Front Lock-Rite~Yakima Load Warrior~33x12.5 Pro Comp M/Ts~Cragar 15x8 Streetlocks~Cobra 18 WXSTII~Marlin Crawler Rear~Addicted Offroad Front Bumper~4X Innovations Sliders~WabFab Bikini Kit~Optima Yellow Top~SS IFS Truss. My 4Runner and Other Stuff |
#12 (permalink) | |
Quote:
). The stock 4.88 rear 3rd member has to be replaced to regear (but not the front). So my advice is get a 3rd already setup with the gears and locker you want from someone who is good at setting up gears...like ZUK http://www.gearinstalls.com/ or ORS http://www.offroadsolutions.com/meetthestaff.htm. And don't buy cheap import gears unless you want to regear often. US gear is made and heat treated in the US. Zuk I think also likes Precision gears.
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. Last edited by mt_goat; 08-31-2007 at 06:41 AM. |
#13 (permalink) |
You can't regear the factory 4.88 thirds because the pinion is offset.
__________________
#14 (permalink) |
I went to Auburn this past weekend from ATL... drove 290 miles with the 5.71/33 combo on 14.1 gallons. I dont know how far off my speedo is ( 10-15% would be my guess) but in my book that is still pretty good.
And I'm loving the 5.71's around town. Anyone wanna race? |
#15 (permalink) | |
Location: NW Ark on wooded ten acres...Ozarks at large!
Success....love to hear it.
So, it's just the rear that has to be swapped out on the 4.88's? Guess I misunderstood. Thought it was the front, too.
__________________
Matthew Context is everything.... Quote:
http://www.yotatech.com/misc.php?do=flashchat |
#16 (permalink) | |
Quote:
![]() The other Runner I had was an 87...22RE/auto/571/33x10.50....not as fast as the 3.0 Runner but pretty good of the line for a 22RE auto. About 3300 rpm at 75 real miles per hour(per GPS) ....revvy but the cruise control held it most of the time without downshifting. Never had a 'stall' problem on the trails I took it on. (Staceman can recall the time on the Crown King trail where I made it up the loose rutty hill with minimal probs (only had the 571's and rear Detroit) and a TJ with a front locker, bigger tires and the 4.0 engine just could not stay on the line up the hill and kept sliding around and had to carefully back down and take the Nissan route....oops, did I say that ![]() My first experience with 571 gears was back in 1986 when I had an 84 Toyota red longbed and was one of the few 4x4's on the trail (at the time) that had Detroit Lockers both ends and low 571 gears. I used to drive that combo with 33" tires(considered to be the biggest tire any serious Toyota owner should use for the rocks) and the 5 speed to Moab Utah once or twice a year.....when the Easter Jeep Safari crowd numbered at a massive 700 people.
__________________
www.gearinstalls.com 2001 white Xtra-cab Taco 3.4L auto TRD 88 Runner/V6/auto/31"/5.29gears ZUK was what my friends in 1990 "tagged' me with when I was building a brand new white 1990 Sami for a magazine cover. The name stuck and I haven't been able to shake it off....not even with antibiotics. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| wtb 4.88, 5.29 or 5.71 gears | kermit84 | The Classifieds GraveYard | 2 | 01-17-2007 05:02 PM |
| 5.71 gears in a stock housing | titicaca | 84-85 Trucks & 4Runners | 10 | 10-01-2006 07:10 PM |
| WTB:8" axle gears(5.71) and lockers | tech | The Classifieds GraveYard | 1 | 05-15-2006 04:48 PM |
| open diff. gears are the same as TRD locked gears???? | byron4 | Offroad Tech | 3 | 05-02-2005 12:35 PM |
| 33x10.50's ??? | carose725 | 95.5-2004 Tacomas & 96-2002 4Runners | 13 | 03-16-2005 03:24 PM |
