33 x 12.5 on stock rim?
Old 09-20-2007, 05:13 AM
4JOGGER's Avatar
I have a 1990 4Runner SR5 with Downey springs and torsion bars.
Is it possible to fit 33x12.5 tires on stock aluminum rims and get no rubs? Is it even possible to fit 33x12.5 on stock aluminum 15 inch rims?
Thanks.
Old 09-20-2007, 05:36 AM
Rommi's Avatar
once I put 37x12.5 MT/R-s to 8" mangels rim. It didnt look good and offroad perfomance wasnt good either. 12.5 inch tire fits perf 8-10" rim... stock rim should be 6-7", i think its gonna look like rubber donut.
here is pic: http://www.4x4matk.ee/4Runner/photos/IMG_0002.html
greetings,
rommi
Old 09-20-2007, 06:02 AM
AxleIke's Avatar
Possible. You may have trouble getting them mounted. Most tire places will want an 8" rim for that wide of a tire, but you can ask before you buy.
You will experience rub, however. You will have to pound the pinchwelds flat, and even then might rub when stuffed and turning, depending on how much crank you put on your t-bars.
Old 09-20-2007, 06:47 AM
terryjmatthew's Avatar
Mounting the tires will not be a problem. I run 12.5" wide tires on my factory 7" wheels.
Can't help w/ the actual fitment.
Old 09-20-2007, 07:06 AM
AxleIke's Avatar
Up here, both discount ire and costco wouldn't mount to a 7"
Old 09-20-2007, 07:11 AM
4JOGGER's Avatar
Hmmmmmmmmmmmmmmmmm. Doesn't sound good but there is probably a reason. Thanks
Old 09-20-2007, 07:12 AM
One of the perks of running a tire store, I guess...
4JOGGER's Avatar
Nice new shoes! How do they ride on pavements?
Old 09-20-2007, 07:18 AM
They ride pretty good, but there is no mistaking that they are mud tires.
Old 09-20-2007, 07:19 AM
4banginRunner's Avatar
mount your own!
no problems with 12.50s on 7" rims here, i had a spare 33x.12.50 on a 6" rim as well, no major problems as a spare..wouldnt use a 6" and a 12.5 on the street
as for rubbing, there should be little, no problems handling a 33x12.50 might rub at full lock and or under full compression
Old 09-20-2007, 07:20 AM
AxleIke's Avatar
Eh, I'm sure you'll be fine. The tire stores around here are sorta dicks anyway. just warning you to ask before you pay someone the money.
Old 09-20-2007, 07:22 AM
Totally OT here, but still amusing.
When wire wheels were the "in" thing, we used to mount 155/80R13's on 13x10 reverse knock-offs.
Talk about a bitch to mount.lol
Old 09-20-2007, 07:23 AM
AxleIke's Avatar
On a 1990? I had serious rubbage with 1.5" lift on my 87, with 12.50's. Perhaps they will be fine. Good luck.
Old 09-20-2007, 07:25 AM
4JOGGER's Avatar
Thanks guys!
Can't wait to have enough doughs to get me a set of 33x12.5!!!
Old 09-20-2007, 07:26 AM
4JOGGER's Avatar
Dang! Didn't see your comment until I had posted my last comment.
Old 09-20-2007, 07:38 AM
Fossilized
Staff
dropzone's Avatar
One option to consider would be a set of 33x10.50's...would mount on the stock rim w/o issue..Seems like you would have some serious bulging putting 12.50's on a 7" rim...
Old 09-20-2007, 07:41 AM
4JOGGER's Avatar
Thanks. I guess I will have to consider new rims too.
CJM
CJM's Avatar
It will fit the rim fine.
It will rub horribly at turn and on the pinch weld. you need at least a 2" body lift to run them and a wheel spacer or a crank on the torsion bars. Otherwise they will rub the upper control arms, the pinch weld, the body and at full lock/turn.
33x10.5 will run fine on a stock rim and no lift, thats what you want if you dont have a lift.
Old 09-20-2007, 07:48 AM
4JOGGER's Avatar
OK. How's this. 33x12.5 on stock rims with 2 inch body lift and 1 inch spacers?n
Old 09-20-2007, 07:50 AM
CJM
CJM's Avatar
Still may run the pinch weld but you can pound that flat if need be.
Why dont you just get a 2" suspension lift with balljoint spacers up front and land cruiser coils in the rear and find rims with less than 4" of backspacing? 3.75 backspaced rims and fender flares will allow you to run 33x12.5's with a 2" body lift with ease, no rubbing, nada but a suspension lift is better. The backspacing acts like the wheel spacer.
What do you wanna do? Do you want a true lift or do you wanna be a mall crawler?
Quick Reply: 33 x 12.5 on stock rim?
