Old 04-21-2016, 03:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Tire Repairs and Maintenance
Print Wikipost
33 inch tires... .What gears?
Old 11-25-2012, 06:27 AM
77camaroCIVICkiller's Avatar
i have 33 12 15 on my truck right now, with the stock gears. do i absolutley have to change my gearing? if i dont will it hurt anythig
Old 11-25-2012, 06:45 AM
vasinvictor's Avatar
Search and stop bumping old topics
Old 11-25-2012, 03:43 PM
suncomb1's Avatar
You should run 4:88 gears. You will find that 4:88 gears with 33" x12.50x15" tires installed on your truck closely matches the stock Toyota truck's rated RPM and torque range. You will feel little difference in driving from stock with regards to acceleration or highway RPMs. Your handling will be better due to the wider tires but you will possibly have some hydroplaning in wet weather depending on the tires you select (Toyota trucks are light).
Old 11-25-2012, 03:49 PM
YOTA-BIRD21's Avatar
I'd run 5.29 gears more get up and go with the bigger tire. and heavy duty
Old 11-25-2012, 08:04 PM
  #25
TrikeKid's Avatar
I run 4.10's and 33's, had 35's previously. Worked just fine. Taking off on a hill with the 35's when the truck was cold was a bit of a bear sometimes but I have a carburetor too. I spent the money for 4.88's on my last truck and yeah it is nice but not nice enough for me to dump any money into the IFS diff.
Old 11-25-2012, 08:10 PM
  #26
westjohns yota's Avatar
i had 5.29s an 36s with a 22re 5 speed, and my speedo was right on, on the interstate at 70 i was running 2800 rpms, really depends on tire size too how your rpms are, with 35s youll run higher rpm with the same speed, bigger tire lower rpm, more speed, just dont expect to go over hills without down shifts
Old 11-26-2012, 02:06 AM
  #27
Matt16's Avatar
Recall the 22RE is pretty rev-happy and big tires not only act as a rubber overdrive, but also weigh more, significantly more than the stock 28" tires.
Old 03-05-2017, 07:28 PM
  #28
Coolsteve0502's Avatar
Hey guys so i was going to get 33inch tires for my 1994 toyota pickup with 4.10 gears i was wondering if that would work or even if i can go up to 35inch tires
Shaun Crystal Gomban
07-30-2015 10:13 PM
coffey50
07-28-2015 10:55 AM
colasurdo
07-17-2015 11:29 AM
HaydenConQueso
07-12-2015 05:22 PM
Quick Reply: 33 inch tires... .What gears?
