32x11.50 or 33x12.50 ??????
Old 02-29-2008, 05:11 PM
mrnick1979's Avatar
i did a 3.4 swap and added a 2 inch body lift on my 94 4runner for engine clearance, i bought 15x8.5 centerline wheel with 4'' backspacing and was wondering if anyone knows if a 33x12.5 on 15x8.5 wheels wiil fit without rubbing. i know with a 3'' body lift you can run 33x12.50 tires on 15x10 wheels. i was thinking that the 15x8.5 wouldnt rub because it sticks out 1.5'' less. if i dont go with 33" tires i will just go with 32x11.50 tires and just turn down the torsion bars an inch to make it look a little better. what should i do? 33's or 32's
Old 02-29-2008, 05:25 PM
olharleyman's Avatar
I think you will be fine with the 33x12.5 with that much backspacing.
I run 35x12.5 on an 8" rim and only had to shave a bit of the pinch welds to stop the rubbing , with the 33x12.5's I had no issues with rubbing on my 4" suspention lift only see if you can test fit a set if your still unsure
Old 02-29-2008, 06:08 PM
89XTRA's Avatar
I had 33x12.50 M/T on my truck with no lift...well t-bars were cranked a little and I didn't rub. And I now have 32x12.50 BFG A/T and they clear just fine, just backed the t-bars back down to make it purty. I would go with the 33's though, just my opinion.
Old 02-29-2008, 06:44 PM
Jay351's Avatar
33x12.50 The 3.4 likes lower rpm crusing
Old 02-29-2008, 10:48 PM
crolison's Avatar
33x10.5 maybe? if not i would go 33x12.5
Old 02-29-2008, 11:52 PM
CC_yota's Avatar
32x11.50 will fit stock with only minor rubbing so 33's should fit fine
Old 03-02-2008, 05:20 PM
mrnick1979's Avatar
so far i hear 33x12.50, i just dont want to buy the tires and have to crank my tbars up, again i am only running 15x8.5 whhel not 15x10, they are 4 inch bs. is anyone out there just running a 2'' body lift only? what tires do you reccomend?
Old 03-10-2008, 05:49 PM
mrnick1979's Avatar
bttt bump
Old 03-10-2008, 06:38 PM
bigarms23's Avatar
go with 34x10 ss ltbs
fountain
02-28-2016 10:13 AM
94toyy
12
09-14-2015 06:18 AM
4mydogs
17
04-07-2006 06:38 PM
Twinkie
04-01-2005 08:54 AM
4x4Lamm
12-06-2003 08:05 PM
Quick Reply: 32x11.50 or 33x12.50 ??????
