32x11.5 R15 on 94 pickup
I'm going to be getting these saturday, and i was wondering if these will fit on my truck with any rubbing ? Truck is completely stock.
http://sfbay.craigslist.org/sby/pts/492577154.html
i'm running 32's on a 15x8 inch rim, I had to cut the lower valance in the corners. I am running the mt/rs so they may be a little more agressive, you should be fine. Lets see pics when u get them on!
They should fit, with the offset of the rims you have on there. Mine rubbed when turning full lock, but that's when it was stock with 32's on 15x9 inch rims and sticking way out the sides. Now with my moderate lift, Downey torsion bars and lift shackles, they don't rub at all. Now I can fit 33's no problem, but that'll be after my MT/R's wear out. Here's some pictures:
[IMG][/IMG]
[IMG][/IMG]
i had a 93 xtra cab. 32x11.50 on 15x8 rubbed pretty bad in front when turned at full lock. they rubbed at the back of the wheel well near the firewall. chewed up the plastic inner fender pretty good. had to cut some out and take a bfh to the pinch weld. then i found some 31x11.50 that would only rub very little at full lock and suspension compressed. i was totally stock, no torsion bar adjustment or anything.
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
