31's Rub on BJ Spacers?
Old 06-21-2008, 12:19 PM
Trustyrusty's Avatar
Hey guys, Finally decided I'm getting 31x10.5x15 Treadwright M/T's and I need rims to put them on, I want Cragars D-Window Black steelies but I need to know what backspacing to get to make sure balljoint spacers WONT make the tires rub on the upper A-Arm, I would also like a little wider stance than I have, I will eventually be getting balljoint spacers up front and don't want them to rub when I install them, if anyone knows that would be great, I have no clue about rim backspacing or anything like that, thanks.
Old 06-21-2008, 12:20 PM
Also what is my bolt circle spacing? I forgot..
Old 06-21-2008, 12:24 PM
Alex 400's Avatar
6 on 5.5"
Old 06-21-2008, 12:49 PM
Junkers88's Avatar
Why don't you use the stock rims? I used my alloys with some treadwright 31/10.50/15 OTR's and no lift and nothing rubs.
Old 06-21-2008, 12:53 PM
Ever seen a stock rim off a base package '86. One word. FUGLY.
Old 06-21-2008, 01:02 PM
Junkers88's Avatar
Ouch. I actually like my wheels although I'm not sure what the difference is between the SR5 package (mine) and a base package.
Old 06-21-2008, 01:07 PM
http://img.photobucket.com/albums/v1...t/IM000421.jpg they look like Shokk88's? Or whatever his name is did.. Whats stock backspacing I hope someone will chime in..
Old 06-21-2008, 02:55 PM
norcalsvx's Avatar
get some 15x8 4"backspace i run them with BJ spacers and 33's so youll be fine
Old 06-21-2008, 03:36 PM
85toy's Avatar
he said he wants a wider stance so wouldnt 2" back spaceing be what he wants? or am i way off?
Old 06-21-2008, 03:43 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Nope...that's right. The lesser the number, the wider the stance......the rim sticks out further from the hub.
Yeah....I have the stock steelies for my '86....6" wide. I don't know what the backspacing is, though. I can tell you any base or SR5 7" Toyota rim will solve the rubbing issue. But, again, I don't the backspacing.
Old 06-21-2008, 06:46 PM
I think I want 3" backspacing If I can find it, 2" sounds 'tarded..
Old 06-22-2008, 05:12 AM
Yopar's Avatar
My stock SR5 aluminum rims (like Junkers88 above) have 4.75" backspace. Now I am running the Tacoma 16" rim, which is more like 5".
Norcalsvx said use 4", which I think would be a good compromise of fitting, and a little wider stance than stock. Maybe go 3.5" but not any less, they'd stick out too far.
Old 06-22-2008, 03:25 PM
Jay351's Avatar
I would go with a 15x8 with 3.75-4" of backspacing.
Im running 3.5" of backspacing and my tires stick out around 3".
4x4YOTA
08-23-2016 09:08 AM
89YodaRunner
09-30-2015 02:18 PM
JookUpVandetti
09-30-2015 08:58 AM
myotherrideisayoshi
09-29-2015 05:41 AM
crash813
09-27-2015 07:15 AM
Quick Reply: 31's Rub on BJ Spacers?
