3.slow and exhaust sensors.
Ok I know theres 2 sensors in my exhaust. One pre cat and one post. Are they both o2 sensors? I'm getting ready to run some new exhaust because I have a broken joint. Just wondering if my post cat sensor will need to be re-installed in the new pipe and if hollowing out the cat will affect anything in the computer.
1 Post
I got a 3.0 and I only have one sensor and it's before my CAT. That is the O2 sensor. Don't know why there would be one after your cat on your model of truck/engine, etc.
Do you have an anomoly or is it because mine is just a Canadian model truck?
My understanding, and I could be wrong here is that the 2nd sensor behind your cat is an O2 sensor. From what I gather it does not effect your fuel air mix but is there to check if your cat is working properly. It is like an emmision check. If you remove it your truck should run fine but you will have a check engine light uless you add a O2 Simulator. Also if you remove your cat and leave the 2ns sensor in you will get a check engine light. I hope Im not lying to you and I hope this helps.
my 22re has the same setup.
ive seen some yotas with them and some without them.
Try YotaND's suggestion, it should work.
As for the cat just make a straight pipe with the tabs on the end to bolt in place of the cat ^-^ thats my plan after i get it smogged or if i get a 94runner. that way when you have to get smogged just sawp and smog it andswap back
If you have a vehicle that came with 2 O2 sensors (but I didn't know any of the 3.0s did), then yes the 2nd sensor is there to make sure the cat is working properly and the ECU will throw a CEL if you gut the cat. BTW that cat has about $140 worth of precious metals inside.
Yeah its definatly in NJ and definatly has two O2 sensors. I wonder how the truck made it across the country, time for a carfax I guess...
As for the $140 precious metal comment is that suppose to be a reason not to gut it or are you saying to sell it and put a straight pipe? Here if theres no cat shell and a cop really want to break your balls he can give you a summonce for court where at the extent of the law they will fine you $5000 for breaking emissions laws.
And possibly the vehicle wasn't shipped for the California market. Maybe it was shipped for sale in a different state & was taken there afterwards by one of the previous owners.
You would really need to run the vin to find out if the vehicle is a California or federal model.
As already mentioned, if you do, in fact, have 2 O2 sensors, then the downstream one is for the cat., checking to make sure that it's working and without it you'll throw a CEL..
FWIW, you'll gain nothing by removing to cat., no power gain, no gas milage gains.
Fred
Fred
I find that hard to believe. Your telling me Toyota actually put a CAT on there that flowed enough for the motor? I've never owned nor seen a stock car that didnt have an improvment with a gutted cat. Maybe too much v8 experience?
