| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
3.slo to 3.4
__________________
95' 4runner -- sold 82' 4x4 -- organ donor for the 93 - but for now summertime playtoy 93' 4x4 extended cab --- Mods; buffalo dents- Future mods; SAS, 33"s, dual cases, motor rebuild 85' MR2 -- It Liiiiivvvveeeeessss!!!! and is almost on the road 87' EX500 -- basket case frankenbike "life, liberty and the pursuit of all those who threaten us" |
#2 (permalink) |
I did it the easy way... I got the ORS harness. But I also did my swap over a year ago before alot of people had done the swap. I didnt have the time to figure out the diagrams.
__________________
1997 Toyota 4Runner, 3.4L (5VZ-FE), 5-Speed (R150F), 4WD, 4.10's, 33's 1998 Toyota 4Runner, 3.4L (5VZ-FE), 5-Speed (R150F), 4WD, 4.10's, 33's 1991 Toyota 4Runner 4 Door, 3.4l (5VZ-FE), 5-Speed (R150F), 4WD, 32's, 4.10's |
#3 (permalink) |
hosh,
there are a number of very large posts/threads on the "3.0 to 3.4 swap". search that exact phase, poke around a few threads and if you haven't found your answer, hopefully people will chime in after the hangovers wear off bob |
#4 (permalink) |
thanks. I looked at ors but they want to much for what should be a $300 to $350 doller harness adapter. Its only hard to make it the first time when you do it as a business
__________________
#5 (permalink) | |
Quote:
#6 (permalink) | |
Quote:
After I thought about it, the price isnt that bad. I didnt have the time to do te research and it was a key piece to making my rig run again. Who knows what would have happened if I had built my own adapter? I didnt want to find ou the hard way!
__________________
1997 Toyota 4Runner, 3.4L (5VZ-FE), 5-Speed (R150F), 4WD, 4.10's, 33's 1998 Toyota 4Runner, 3.4L (5VZ-FE), 5-Speed (R150F), 4WD, 4.10's, 33's 1991 Toyota 4Runner 4 Door, 3.4l (5VZ-FE), 5-Speed (R150F), 4WD, 32's, 4.10's Last edited by 914runner; 01-02-2006 at 05:11 AM. |
#7 (permalink) |
Just his opinon, don't flame the guy to ashes. True the harness may be a little pricey but when you do your swap you will see the research and consentration it will take for the wiring. It's not hard but it's time consuming and you have to be careful. Plus ORS has to get the parts up for your particular swap. I didn't get their harness but if I didn't know about wiring I would have gotten it in a heartbeat. Anyways, I PMed you with that info that you asked for. Let me know if I can help anymore.
__________________
91 4x4 4runna 3.4 , auto to manual tranny conversion, 2" body lift, Aisin manual hub conversion, vinyl flooring, 2nd gen inclinometer, 2.5 Magnalow cat & muffler, Trail Gear Sliders, Bilstein Shocks *Gone but not forgotten 96 4runna Limited e-locked, KC Fogs, 265/70/16 Hankook Dynapro ATm's |
#8 (permalink) | |
Quote:
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. Last edited by mt_goat; 01-02-2006 at 08:35 AM. |
#9 (permalink) | |
Quote:
R & D ain't FREE...
__________________
UZswap.com A site dedicated to sharing info for swapping the Toyota/ Lexus UZ (V8) engines into Toyota Trucks and 4Runners. My 4Runner 1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys, low lift, hacked fenders, tubbed firewall, custom armor TOOLandFAB.com A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion |
#10 (permalink) |
Sorry about ticking you all off. I know there is alot of research, specially since there are about 50 different possible combinations of years. I'm in the middle of it right now, but tell him to make a peg board. I'm also very sure his will look better than mine. Although i wasn't aware it was so hard to get connectors. But last time i checked $650 dollars was alot of dough for and average joe.
__________________
#11 (permalink) |
Don't forget the endless phone calls answering questions about the whole 3.4 conversion. You will probably need to hire a full time employee to answer the phone just so you can get some work done. And of course the employee won't know all the answers so for the first year or two you'll still have to stop what you're doing and explain everything to someone who may or may not even buy anything from you. Then of course that employee you have finally gotten trained after 2 years will leave to go back to finish college and you'll have to start all over again with some newbe than doesn't know an engine harness from a heater hose.
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. Last edited by mt_goat; 01-03-2006 at 07:13 AM. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Damn it's 3.slo! | Schralper | 86-95 Trucks & 4Runners | 23 | 05-29-2007 11:39 AM |
| Craigs List SLO | funjumper | 86-95 Trucks & 4Runners | 1 | 03-29-2007 08:23 AM |
| headers? 3.slo | Schralper | The Classifieds GraveYard | 8 | 02-15-2007 04:58 PM |
| SLO County 4wheeling | funjumper | Off Road Trip Planning, Expeditions, Trips, & Events | 1 | 02-08-2006 05:25 PM |
| SLO\Pismo area wheelers check in!! | Mikronized | Off Road Trip Planning, Expeditions, Trips, & Events | 36 | 02-12-2004 01:36 PM |
