#3 bypass re-route
Old 03-28-2013, 06:55 AM
KEB
KEB's Avatar
#3 bypass re-route
I have a 1990 4runner that has a clogged by-pass pipe not the #3 hose but the pipe once it leaves the hose. Has anyone re-routed the #3 hose over to the #5 by-pass hose? I want to do this due to the cost of replacing the existing hard pipe that is under the intake manifold, etc. Thanks
Old 03-31-2013, 11:44 PM
Co_94_PU's Avatar
Wouldn't clearing the pipe be easier than building a "Y" and blocking off #3's down tube? I mean sure you gotta take of a bunch of stuff to get to it to remove it but seems kinda wrong to go messing with the cooling system on those.
*Shrug* run with the heater valve open and think about it.
Old 04-01-2013, 04:06 AM
KEB
KEB's Avatar
Yes, I agree...I have tried to clean but cannot get past the first turn in the pipe?
Old 04-01-2013, 05:00 PM
Co_94_PU's Avatar
It's off the engine?
Fill the tube with CLR or vinegar and let it soak it's way thru.
For a "tool" I'd go with piano wire, a soft copper coat hanger, and/or some light duty multistrand cable chucked up in a hand drill. (Like bicycle brake/shifter cable). Just have to use the right rotation so the cable doesn't try to unwind, think plumbers snake.
Worse case you could cut it off and put a flare nut on the pipe section you have to keep, and put a 8-12" solid brake line on there. Not sure how that'd work out depends how tight the space.
Good luck, stick with it and you'll get it fixed!
Old 04-02-2013, 03:59 AM
KEB
KEB's Avatar
Thanks but it is not off the engine...I have tried a coat hanger with a drill and a more rigid wire but that did not work either...
kawazx636
10-06-2021 03:03 PM
kcaudill
10-10-2015 02:39 PM
mtrdrms
09-26-2015 07:12 AM
elaketiger
09-14-2015 09:58 AM
zz_denis
09-06-2015 03:43 PM
Quick Reply: #3 bypass re-route
