| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
3" body/drivetrain lift. New Driveshafts or not?
__________________
89' 22RE 5spd. (Daily/pizza beater) 87' SR5 4runner (Soon to be DD/Trail rig) |
#2 (permalink) |
Without any other suspension lift your stock ones will be fine. At least the rear one.
Someone else should be able to tell you about the front. |
#3 (permalink) |
If You're doing a body lift you shouldn't need to change your drivetrain at all, doesn't just the body move up off the chassis?
__________________
"I'll live forever...or die trying! '89 4Runner, 3.0, 4" lift, k&n filter, tornado, Rear air ride Soon to come: Front air ride, and manual adjustments with pressure gauges on the driver's side pillar |
#4 (permalink) |
...true, if you are just doing a body lift...that's not what I'm talking about. The only reason i want the body lift is so that I can also lift the whole drivetrain and gain lots of clearance under the center of the truck. It's pretty common.
__________________
#5 (permalink) |
What do you need to do to raise the drivetrain?
#6 (permalink) |
I didn't have to change anything when I added a 2" drivetrain lift to my '85:
- http://www.4crawler.com/4x4/CheapTri...ft/index.shtml All depends on how close your shafts are, lengthwise, at the present time. As long as you have sufficient slip yoke spline engagement, should be fine.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#7 (permalink) |
Motor mounts and T-case crossmember, and hopefully not lengthen the driveshafts
__________________
#8 (permalink) |
so do you have to cut the horse collar crossmember out if you don't have dual t cases?
__________________
94 4Runner 3.0 5spd 31" BFG A/T Custom Bumper 150w KC Daylighters |
#9 (permalink) | |
Quote:
![]() http://www.4crawler.com/4x4/ForSale/...l#Introduction
__________________
| Tags |
| clearancing, crossmember, horsecollar |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Pinion angle adjustment with 1" drivetrain lift | Snorkeldepth | 86-95 Trucks & 4Runners | 3 | 02-29-2008 08:04 AM |
| 3" Drivetrain/Body Lift + New Crossmembers = ... | ravencr | Offroad Tech | 59 | 03-21-2006 04:01 PM |
| Bud Built crossmember for 3.0 5spd with 3/4" drivetrain lift (pics) | rocket | The Classifieds GraveYard | 14 | 02-22-2006 01:25 PM |
| 3rd Gen rolling on 315/75/16: 2" Suspension lift, 1" Body lift | sschaefer3 | 95.5-2004 Tacomas & 96-2002 4Runners | 114 | 01-02-2005 05:12 AM |
