3.4 conversion and CA Smog tests - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-07-2006, 11:51 AM   #1 (permalink)
My '94 4runner with a 3vze is ill. This may be a good time to do the 3.4 conversion.
How hard is it to get a 3.4 conversion smog checked in California? After the first test, how hard is the retest when the two years is up?
Does anyone have a donor vehicle for sale?
funjumper is offline
Old 12-07-2006, 11:56 AM   #2 (permalink)
Staff
Tofer's Avatar
Send a message via ICQ to Tofer Send a message via AIM to Tofer Send a message via MSN to Tofer Send a message via Yahoo to Tofer
*subscribes*
__________________
94 4runenr: all the good stuff.......
89 4runner: 3.0, Auto, 5.29 lockright f/r. 31x10.5 wildcountry ATs.
81 2wd pickup: 22R | 5-sp | long bed |Civic SI seats | LockRight | Hella 500s
pacific-crawlers.com
For all your Trail-gear and HID lighting Solutions Needs check out yotaworks.com Online store coming soon :)
Tofer is offline
Old 12-07-2006, 12:15 PM   #3 (permalink)
rdharper's Avatar
Good question (which is, of course, why you ask it). I'd check Smogtips.com, and maybe ask a good "test only" station in your area, as well as ask here.
My own thoughts are that I hate to deviate from stock because of the SmogII requirements. You'd think they'd welcome you swapping in a more recent engine which allows you to use the OBDII diagnostics. But I suspect not.
What's wrong with your 3VZE?
__________________
Richard
"Science by consensus... is not Science." Richard Harper -1988
'94 Toyota 4Runner V6 3L 158K miles 14mpg
'85 Toyota 22rec 4WD SR5 LB PU 208K miles 18mpg
'08 Honda Ridgeline RT 2.6K miles 16mpg
'06 Honda Rincon ATV 410miles/65hrs 22 mpg
rdharper is offline
Old 12-07-2006, 12:41 PM   #4 (permalink)
Send a message via MSN to Greg_Canada Send a message via Yahoo to Greg_Canada
I think Chili_Man from 4x4wire did it, so when he smogs, he smogs as a 96' 4runner, but the registration says 87.
might be in here somewhere...
http://www.4x4wire.com/forums/showfl...fpart=all&vc=1
Greg_Canada is offline
Old 12-07-2006, 12:41 PM   #5 (permalink)
norcalsvx's Avatar
you can swap a newer year motor and take it to the ref or do like i do and reg. the truck in a town with less than 500 people (you dont have to live there, just store the truck there) and you wont have to smog anymore (i learned this from my rx7 days)
__________________
1994 toy 22re-
http://www.yotatech.com/f86/nocalsvx-s-94-toy-104593/
2006 Subaru Forester XT -some mods/awd 5spd
1994 Subaru SVX- hwy runner
84 RX7- drag car build
norcalsvx is offline
Old 12-07-2006, 12:55 PM   #6 (permalink)
I started another thread about the illness. Blown HG on a 226k motor.
Old 12-07-2006, 01:10 PM   #7 (permalink)
Tigerstripe40's Avatar
I think the law says that you must use an engine the same year or newer than what you are replacing, and that all of the emissions controls on the donor engine need to be in place. For something OBDI this isn't that tough.
But to swap in and remain OBDII compliant that is a WHOLE other ball of wax.
Basically, they connect the emissions computer to your ECM and download. If it throws ANY code, you fail.
__________________
-James
-76 fj40 'SeldomSeen'
-91 4Runner 'Mr Snuffalupagus' aka 'CanOWorms'
3.0 rebuild gallery
What the FJ Cruiser should have been.
Tigerstripe40 is offline
Old 12-07-2006, 01:50 PM   #8 (permalink)
sloth!'s Avatar
You go to the ref the first time. he goes over it with a fine tooth comb and if it passes his visual and then the particulate test he will slap a ref sticker next to the current stock smog sticker under the hood. then you can go to a reg smog shop for your 2 year smog. they will then run it off the smog ref sticker rather than your current vin and stock smog sticker.
\make sure you do your wiring very cleanly as he will trace a number of wires from the ecu to the sensors to make sure you arent faking it. He might also check your ecu part # to make sure it is for the right model and trans as the swapped motor. He will check that the CEL works. if it is an ODBII motor he will likely plug his machine into the ODBII port and run various tests. If it is ODBII motor you will need the new style of catalytic converters that are ODBII compliant, stupid but true.
__________________
90 xcab, sased, arbs, 37s, marlin dual cases, warn, longfeilds, bobbed, ready for the mall.
94 4x4 DD
06 tundra CC 4x4
sloth! is offline
Old 12-07-2006, 02:00 PM   #9 (permalink)
SacRunner's Avatar
Send a message via AIM to SacRunner
My understanding from reading in Downey's catalog, and a few other places, is that the engine must be of the same year or newer, out of the same class of vehicle (light truck -> light truck (3.4L would fit here); NOT car -> light truck; NOT heavy duty truck -> light truck), and have all the emissions components as mentioned earlier.
At some point a smog referee must inspect the conversion (not sure totally what that includes), if it passes you're issued a metal ID tag that gets bolted to either the inside of the driver's door jamb or under the hood. Future smog tests will be done based on the emissions standards for the newer engine, not the year of the vehicle, and I THINK can be done just as usual.
There might be some requirement about keeping the same type of transmission (manual vs auto) but I really don't know.
as far as i can remember this is accurate, but if anythings not, please let me know and i'll change it...last thing i want to do give wrong info.
__________________
-Wallace
'91 4Runner | 3.0 | 5sp | 4WD | 33x10.5r15 BFG AT | 15X8 Cragar black steelies | BJ spacers | OME 901 coils | OME shocks | OME steering stabilizer | Sonoran Steel Rear IFS Truss | ISR mod
SacRunner is offline
Old 12-07-2006, 02:31 PM   #10 (permalink)
In the interest of making the smog ref happy, I was figuring on lining up the donor motor, ECU, etc, then buying the ORS complete kit. I don't plan to sell this 4runner for a very long time, if ever. I am willing to spend the $$ (to a point) to make a neat and clean install.
That is, if I can get a warm fuzzy feeling about the likelihood of not having a huge hassle with the smog folks after the first go-around.
Old 12-08-2006, 10:48 AM   #11 (permalink)
I put a 85RE engine in a 84R 4x4 pickup. Had to change a number of things but when it was all done I had to take it to the referee because 84 didn't offer an EFI in that model. He checked a number of things and then put a sticker on it for future smog checks which I will be able to do at any smog check location. As has been stated engine must be equal year or newer and meet all the smog requirements of the newer engine.
I'm getting ready to put a 3.4 into my 91 4runner and will ahve do deal with the same issues. I got a 95 tacoma 3.4 donor which isn't ODBII but I think I'll hook up the OBDII connector anyway.
__________________
91 4Runner - 3.4 swap, Downey headers
89 4Runner - my next project
87 4Runner - fixing up for my daughter's first ride
sat4soris is offline
Old 12-08-2006, 11:08 AM   #12 (permalink)
mt_goat's Avatar
Shouldn't be a problem as long as you use the donor truck cats, O2 sensors, evap can, VSV stuff and use the ORS harness which includes an OBDII plug.
__________________
~Dale~
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000.
mt_goat is offline
Old 12-08-2006, 08:32 PM   #13 (permalink)
I thought some 84 came with efi.
Salusa is offline
Old 12-09-2006, 07:10 AM   #14 (permalink)
I thought they did also but when I took it to the smog shop the first time he said it didn't so I'd have to take it to the referee. Maybe he meant since my particular vehicle didn't come that way I had to go there. The referee was very helpful and thorough.
__________________
Old 02-14-2007, 11:27 AM   #15 (permalink)
jskijoe's Avatar
What year did OBD II start? Don't you have to have 2 cats in CA? If so, how did some of you configure the cats? I'm probably going to go with the ORS crossover to keep it simple and maintain ground clearance. I'm curious if anyone that did the swap with headers had trouble with positioning the cats properly. I would think the cats need to be a certain distance apart with the 2 O2 sensors.
__________________
'91 4x4 3dot slow
3.4 Swap in progress...
Other rides: 2002 BMW 330i
jskijoe is offline
Old 02-14-2007, 11:58 AM   #16 (permalink)
mt_goat's Avatar
January 1, 1996 was the main switch to OBD-II systems. Some manufacturers started earlier. Yes, the cats and O2 senors need to stay about the same distance down stream as the factory set-up or you could throw a CEL, probably a P0420 (Catalyst System Efficiency Below Threshold Bank 1). Ca had 2 cats before other states, but I think 2 cats is a nation wide standard now.
__________________
~Dale~
mt_goat is offline
Old 02-14-2007, 12:04 PM   #17 (permalink)
mt_goat's Avatar
I guess if the Ca state inspector was really looking closely he could ask to see a smog sticker for the ORS custom cross-over and you'd have a hard time getting around that one.
__________________
~Dale~
mt_goat is offline
Old 02-14-2007, 12:20 PM   #18 (permalink)
Quote:
Nice to see this thread come back.
Who here on Yotatech has done the 3.4 conversion in California and successfully gotten through the smog check referee process?
If you have a friend that has, but they aren't a yotatech member, ask them to sign up and share their experiences.
Is there another board anywhere that has success stories on this issue?
Old 02-15-2007, 07:09 AM   #19 (permalink)
rdharper's Avatar
I remember someone in the last 6 months describing the process. It should still be available if you catch the right search. It seemed fairly straight forward.
__________________
Richard
rdharper is offline
Old 02-16-2007, 07:32 AM   #20 (permalink)
I'm in the middle of the swap right now. Hope to put the 3.4 in this weekend. Should be taking it to the smog referee station fairly soon and will let you know any issues that arise. Here is a link to some OBDII info that I found helpful.
http://www.obdii.com/connector.html
My donor engine is a 95 1/2 Tacome which is not OBDII but I plan on adding it. I'm planning on using a 97 ECU which will work and give me the OBDII info.
__________________
Old 02-16-2007, 09:00 AM   #21 (permalink)
mt_goat's Avatar
I've been told that in most states the "ECU year" will determine what standards they expect your truck to pass. So, if you have a 97 ECU you'll have to be OBDII. I'm not up on CA laws though.
__________________
~Dale~
mt_goat is offline
Old 02-16-2007, 12:17 PM   #22 (permalink)
rdharper's Avatar
That would make sense, as that allows the Smog process to identify the engine type electronically, and apply the standards for that vehicle.
__________________
Richard
rdharper is offline
Old 02-19-2007, 04:25 PM   #23 (permalink)
Hey everyone im new very new to this forum and I had a few questions for all you...I just purchased a 90 runner with a blown motor. Im trying to decide if I want to go with the 3.4 swap or just stick another 3L back in it? Besides all the issues with the smog and what not is it common practice to swap the tyrannies to or will the 90 manual tyranny hold the extra power?
jakes_runner is offline
Old 02-20-2007, 07:47 AM   #24 (permalink)
jskijoe's Avatar
From what I've heard from most people is that the manual tranny that comes with your V6 is plenty strong for the 3.4 and it bolts right up. You have to use the 3.4 clutch though. I'm choosing to swap the 3.4 because I won't get the power as easily as if I swap the 3.4
__________________
'91 4x4 3dot slow
jskijoe is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
22r mods for CA SMOG deserttoy84 84-85 Trucks & 4Runners 1 02-23-2006 10:15 PM
CA smog on a 1st gen Tacoma Dude Maintenance & Repair Archives 1 04-05-2005 05:01 PM
CA smog help Tokez420 95.5-2004 Tacomas & 96-2002 4Runners 17 06-25-2004 06:53 AM
help me pass CA smog test please 2wd1stgen 95.5-2004 Tacomas & 96-2002 4Runners 9 06-05-2004 07:43 PM
smog in ca rollandfayssoux 95.5-2004 Tacomas & 96-2002 4Runners 1 12-01-2003 02:31 PM
2009 InternetBrands, Inc.
