Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
3.0L rod knock repair
I'll be pulling the engine (it still runs) this week to fix the rod knock and determine if the block/crank are any good. The truck is a 1995 and I have access to a shortblock from a 1989 pickup. I think the timing belt tensioners are different. Can the shortblock from the '89 be used with the '95 heads? I hope I just need new rods/mains.
| Sponsored Links |
#2 (permalink) | |
my 22re did the same it had a real bad rod knock i mean really bad and then it locked up on me but yours still runs so i would go to your parts store and get a rebuild kit comes with everything and since you doing main and rod bearings you might as well refresh the whole thing as for the heads no clue man sorry i know 22re's are all the same but not sure for the 3.0's but its not that bad doing a rebuild just take your time and do it right the first time
__________________
GO TEAM LAZY!! my name is ALLAN yeah its a 22re 5-speed 4wd 1987 4runner with a cam, snorkel, welded rear Quote:
www.myspace.com/whatsadisplayname |
#3 (permalink) |
I would recommend that you install a crank kit. I got mine from Marshall through Rock auto and am very happy with the quality. The kit was $200. The gaskets and seals were another $300. Good time to replace the water pump and timing belt, too.
__________________
94 4 runner 3vze 5 speed |
#4 (permalink) |
www.engnbldr.com is hard to beat for a quality engine kit.
__________________
-Bill Red Chili II: 1987 SASed 5VZ-FE 4Runner with more stuff than I can afford. Not that that makes me unique 'round here. Shadowfax: 1993 minitruck. Getting the Engnbldr full meal deal. Hunting truck and DD! Bio Page |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Rod Knock!!! what should i do? | brentcole5 | 86-95 Trucks & 4Runners | 6 | 01-14-2008 09:04 PM |
| Is this rod knock? | 4RocRunner92 | General Vehicle Related Topics (Non Year Related) | 8 | 11-22-2007 05:18 AM |
| '92 3.0 Rod or Wrist pin knock? | Daemon | 86-95 Trucks & 4Runners | 9 | 02-12-2007 09:58 PM |
| Rod-Knock? I've no clue what's going on... | oseas | 86-95 Trucks & 4Runners | 13 | 02-08-2006 07:42 AM |
| HG versus knock sensor repair, need help!! | silverstrand | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 02-15-2005 04:15 PM |
