3.0L oil pressue
Old 02-05-2008, 01:20 PM
88yotadad's Avatar
3.0L oil pressue
How much oil pressure should a 3.0L have. I just got the oil gauge installed and at fast idle the gauge was reading 90lbs. That to me sounds to high. I did not have time to get the motor warmed-up so no idea if the pressure would drop once the engine warms-up.
Roger
Old 02-05-2008, 01:52 PM
Tim_Snapple76's Avatar
i would think that figure would be a bit high, however, this is only a guess.
Old 02-05-2008, 03:03 PM
86tuning's Avatar
High oil pressure, especially with cold oil, is perfectly normal. It basically means you can run a lighter oil. ie, 5w30 instead of 10w30. High oil pressure is a good thing.
If your oil pressure was low, that would be a problem, indicating damaged/worn bearings or oil pump. That would be a bad thing.
Old 02-05-2008, 06:07 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Hey, Roger. You're back!
If the motor's cold....especially if it's cold where you live....that is normal. If it's higher than spec when warmed, that would be a concern.
Is the motor knocking or anything?
Oh, here's the specs....but, of course, this is for operating temps.
http://personal.utulsa.edu/~nathan-b...16oilpress.pdf
Old 02-06-2008, 12:09 AM
88yotadad's Avatar
Yes it making noises but I'm thinking that it is the water pump. We have a small amount of fluid dripping down the block on the drivers side. I can not see from where so I'm assuming water pump.
Old 02-06-2008, 09:24 AM
thook's Avatar
Well, it may be messy, but one way to locate the leak would be to spray aerosol foot powder around wherever a leak is possible. It's easy to rinse off, though.
Does the fan clutch have any play in it?
Old 02-08-2008, 06:52 AM
88yotadad's Avatar
I thinking water pump or timing belt idler is my noise problem. I listened with a stethiscope(spelling). The next project is to fix this.
Roger
Old 02-08-2008, 07:45 AM
yotaman90's Avatar
Does it sound kind of like a scraping sound?
defrag4
07-31-2015 10:50 AM
JefferDean
07-31-2015 10:39 AM
calderp
07-27-2015 09:58 AM
nonstop
07-24-2015 06:29 PM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: 3.0L oil pressue
