3.0 wont start
Old 02-27-2014, 01:57 PM
Corey Barlow's Avatar
3.0 wont start
Last night while driving home my engine shut off like someone flipped a switch but everything else stayed on so I coasted to the shoulder put it in neutral and it fired back up so I drive a few seconds and it does the same thing this time I had to sit a minute till it would start I made it home without it happening again or it acting funny. This morning I try to start it and it won't start I pull the codes and get 14 and 24. I'm getting spark to the plugs and gas to the injectors. I pulled the plugs and there dry I think the injectors are my problems. What could cause the injectors not to work?
Old 02-27-2014, 04:08 PM
Bump.
Old 02-27-2014, 04:14 PM
JasonYota's Avatar
What do the codes mean? You said your getting gas to the injectors but then you say the plugs are dry. Are your injectors working or not?
Old 02-27-2014, 04:27 PM
I have gas in the fuel rail but the injectors aren't spraying fuel in the cylinder
Old 02-27-2014, 04:32 PM
JasonYota's Avatar
Are you getting power to the injectors?
Old 02-27-2014, 04:40 PM
I ran out if day light I'll have to check in the morning. I'm just trying to get some ideas to try tomorrow
Old 02-28-2014, 06:22 AM
earlycuyler88's Avatar
Code 14 is the ignition signal and code 24 is the intake air tempture siginal. I would start by going thru the vafm and make sure its in spec, could definitly be the cause of your problem
Old 02-28-2014, 06:49 AM
Gevo's Avatar
what earlycuyler said...
Here go to page EG@ 176 and read what it says about the codes, very helpful. That is most likely the circuit causing your issues. GO to the page referenced in the column to the far right of each code and follow the troubleshooting steps. Let us know what the fix was or if you need any other help.
http://personal.utulsa.edu/~nathan-b...85diagnosi.pdf
Cheers
Old 02-28-2014, 11:10 AM
Would either one of those cause the injectors not to pump?
Old 02-28-2014, 11:16 AM
Gamefreakgc's Avatar
Yes. If the VAFM is not working correctly then it will not start since it will not activate the COR and not supply any power to the fuel pump.
On the diagnostic port, jump FP and B+ with a paperclip the next time it happens if it starts, your VAFM is going out or there's a short in the wire. Done any "custom" wiring jobs on your intake or ignition?
Old 02-28-2014, 12:23 PM
I've jumped the fuel pump and tried to start it still nothing. I haven't done anything with the wiring. Im getting an igniter in the morning so I'll see how that goes
Old 02-28-2014, 03:46 PM
scope103's Avatar
Igniters are expensive, a multimeter is not. (The HF one will work just fine.)
Check for 12v to ground on B+. Check for continuity to ground on FP (it's through the fuel pump, so you'll get less than 5 ohms).
Old 02-28-2014, 04:54 PM
^^^^ scope103 gives a lot of good advice. If the vafm is not sending a signal to the computer telling it how much air is coming in the computer wont send the sigial to the injectors to supply the gas, which kind of sounds like your problem, i'm not saying it is though. I would get a multimeter and test everything before replacing anything though
Old 03-01-2014, 06:07 PM
Alright got it running. I had some wires that had the insulation broke and were grounding. Got them fixed an wrapped and it's running good now
Old 03-01-2014, 07:35 PM
Nice catch! Hurray for the free fix!
Old 03-01-2014, 10:07 PM
Ha for real. I'd tested a few things they all came back good so I was getting frustrated and noticed how brittle my wire harness looked so I got to playing with them and I got it to crank for a few seconds so played a little more and boom it came to life
Old 03-01-2014, 11:56 PM
Gevo's Avatar
I just took delivery of some heat shielding tape. I dont like how bow close to hot exhause some of these components and wires are. Its not gonna be pretty but its gona be better!
Charecter1
11-06-2023 10:08 AM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
MTLroadierunner
07-15-2015 12:58 PM
Roger Borba II
07-09-2015 05:05 PM
raiderhawks00
07-08-2015 06:23 PM
Quick Reply: 3.0 wont start
