3.0 V6 Cold Starts fine dies after warming up
Old 06-17-2010, 06:05 PM
losmosis's Avatar
I have a 95 4Runner with a 3.0 V6. It starts fine cold and will run fine until it gets warmed up. After warm up 10-15 minutes it just dies and wont start again until it cools off a bit. However it is not running hot. Them temp guage doesn't work very well so I used a temp gun directly on the engine. It read close to the same temp as my 91 3.0 V6. So I know its not hot at 170deg. on the intake.
Acts like you just turned off the key.
Old 06-18-2010, 09:48 AM
losmosis's Avatar
I need help here to guys. I have to get one of these yotas to run. they are both daily drivers.
Old 06-21-2010, 03:21 AM
losmosis's Avatar
Come on guys someone knows the problem.... please help.
Old 06-21-2010, 05:32 AM
Team420's Avatar
I would start with the coil.... those tend to show problems when hot....
Look for cracks, and white marks on it....then test it cold with the multimeter, then again when hot....
report you findings....
Old 06-21-2010, 07:49 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Then, there's coolant temp sensor, air idle control valve, aiflow meter circuit, fuel pressure regulator......
http://personal.utulsa.edu/~nathan-b.../3troubles.pdf
Coil's a good place to start. After warm up? I'd also check the air idle valve and/or coolant sensor.
Old 06-21-2010, 10:01 AM
losmosis's Avatar
The primary side of the coil is out of specs. I have one ordered so I'll let ya know if that is the problem.
Thanks.
Old 06-21-2010, 10:05 AM
losmosis's Avatar
thook the link you just posted. http://personal.utulsa.edu/~nathan-b.../3troubles.pdf
What is the index page? Can you post a link for it?
Old 06-25-2010, 05:12 AM
thook's Avatar
What's the matter? Are you not able to access the page? IOW, I clicked on the link in your post, but it says link can't be found. But, when I click on the link I posted, it takes you right to the 3vze troubleshooting page.
Old 06-25-2010, 08:40 AM
sb5walker's Avatar
http://personal.utulsa.edu/~nathan-b...fsm/index.html
http://www.ncttora.com/fsm/index.html
nvwiggins
13
06-16-2016 03:05 PM
JHalcyonM
09-14-2015 01:10 AM
sanctfy
09-13-2015 06:33 PM
EatChipsNow
09-09-2015 01:25 AM
seab1209
09-03-2015 05:41 PM
Quick Reply: 3.0 V6 Cold Starts fine dies after warming up
