3.0 V6 91 pickup Clutch install help
So im doing the clutch on my 91 pick-up with the 3.0 and i would like to know if i have to REMOVE EXHAUST PIPE ( Remove the 3 nuts, exhaust pipe and gasket from the exhaust manifold) to get the tranny out As the FSM states.
But they are rusted on and striped i have sprayed them with PB for 2 days and i need to get it done to day. As for i have work in the morning. That is the only thing holding me up. if i don't have to remove it that would be nice.
Yes i have a tranny jack & Pilot Bearing Puller
Any help or tips would be nice. thank you
Gonna go back and give it a shot. will check back in few
i just changed the clutch on my 94 v6 and i never had to touch the exhaust. there is plenty of room to get to all the tranny bolts to remove the tranny and change the clutch. good luck
What about the 12. REMOVE FRONT DIFFERENTIAL SET BOLTS
(a) Remove the 3 bolts. (b) Support the front differential.
i dont rember doing that on the last on i did but that was a wile ago
^^ what he said. never touched the exhaust or the front diff. only had to remove the front driveshaft. dont take off more stuff then you need too.. keep it simple man good luck
Seconded (third?)... All I did was disconnect front ds from diff, rear ds from Tcase, Tcase crossmember from frame, ONE exhaust support from the bellhousing... then I unbolted the transmission + bellhousing and took it out. PS Taking off the front skid plate allows "easy" access to some starter bolts that also go through the bellhousing.
Good luck, don't forget to clean out the bellhousing and lube up the clutch fork pivot points before you put it back together!
Got the tranny out and new clutch in & the tranny back in But then I had to go to work still have a few bolts I need to tighten up than test drive. Thank you for all your fast input It helped a lot. Dang FSM wants you do do all kinds of useless stuff. Will let you all know how it turned out.
Thank you !
Well its all back in and it work's nice!
Got it done just in time for my road trip
Thank you all for your fast info it Saved a lot of time and stress
nvwiggins
13
06-16-2016 03:05 PM
scott90
10-04-2015 09:21 AM
