3.0 Timing
Old 09-29-2010, 11:13 AM
WesinTX's Avatar
3.0 Timing
I was adjusting the timing on my 3.0l yesterday and noticed that the mark jumped around about two degrees. It was erratic, no real pattern to it. I was wondering how steady is other peoples marks when they have do this.
Old 09-29-2010, 12:08 PM
blake.nemitz's Avatar
mine does that i dont know why but it always has and seems to run fine, i run mine at 17* with afm cog clicked one degree rich "to help prevent detonation" and premium fuel. im getting about 300 miles a tank so around 20.
Old 09-29-2010, 12:24 PM
WesinTX's Avatar
It runs fine, I was hearing some detention every now and then so I checked the timing and found in at 15*. I cut it back to 10* and the detention is gone, imagine that. Power is about the same, no noticable difference. I was wondering if the mark jumping was caused by distributor noise, worn bushing?
Old 09-29-2010, 04:32 PM
vasinvictor's Avatar
Mine jumps around a bit too when jumpered. It is usually not so bad that I can't establish a base line to set my timing. I run mine at 12* and use 87 with no detonation.
Old 09-30-2010, 03:33 AM
TNRabbit's Avatar
This is usually, but not always, caused by distributor issues.
Charecter1
11-06-2023 10:08 AM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
MTLroadierunner
07-15-2015 12:58 PM
Roger Borba II
07-09-2015 05:05 PM
Quick Reply: 3.0 Timing
