3.0 starts then stalls
Hello,
I looked everywhere I could, but I cannot find the answer.
My 3.0 starts, revs up to 3000 rpms then dies. It was working good the other day until I took off my Air Intake to fix a vacuum line problem that was giving me a high idle (2200 rpms) from when I did my engine swap.
I looked at the FSM and routed all the vacuum lines properly, but I have an extra one now that I have no idea where it goes. My vacuum lines are factory and this one has the *# on it and is about 10" long.
Are there vacuum lines behind the Air Intake that are not on the diagram? I have the TVV to the canister then to the TB hooked up, but this one is a mystery to me.
Any help with the stalling and vacuum is appreciated. Are they connected?
Cheers!
Kevin
Cheers!
Kevin
there is a vacuum port on the passenger side of the Intake (where all the vacuum lines go pretty much.) that has 3 ports on it..for 3 small vacuum lines.
i believe it goes on TOP...i don't think it matters honestly.
but when i rebuilt my 3vz, i taped and numbered all my lines and such, and that's where mine came off.
my 3vz is doing the stalling thing as well, and testing leads me to the AFM being fubarred....
go to the FSM and look up the testing procedures and test yours..very simple.
Other than removing the air tube to check the spark plugs, I did not touch the AFM... But this is a 91... lol
well i didn't do anything to mine except move it from the engine compartment to the back seat of my 4runner..
before rebuild..it was fine, after rebuild...it's not? lol
well that is the only one i seen that has *# labeled on it, and i'm 99.9% sure that's where it goes.
Measured my VAF this afternoon:
Terminals˟˟| My Figure | Toyota Spec
VS - e2 | 312 | 200-600C) - Not sure what C) means
VC - e2 | 279 | 200-400C)
THA - e2 | 0 | 2-3k ohms @ 20 degrees C
Seems my THA - e2 is out of wack. Looking for a new(er) VAF right now.
Does the above support a new VAF?
Replaced the VAF, but still no joy. The VAF was out of spec, and now I'm sure this was giving me the high idle. But I still cannot start the engine for more than 3 seconds before teh idle drops to 300 rpms then stalls.
Going to bypass the EGR today and test the cold start circut. Anyone else have any ideas?
Cheers!
Kevin
Cheers!
Kevin
Crack in the intake plenum... ;(
Must have done something wrong when I reinstalled it..... crap where can I get one for a good price in Ontario Canada?
I'm having the same exact problem (Starts right up, goes to 3K, drops off and dies) after I just changed out the spark plugs, wires, cap, rotor, and cleaned the air filter and connected the charcoal canister to the BVSV (wasn't connected and I failed emissions).
I didn't do anything to the AFM other than set it on the ground when i removed the intake tubing to do the drivers side plugs.
my plugs were gapped to .034 (I know stock is .032, but i read .034 was doing better fuel mileage). They're NGK V-Power
Cap and Rotor are just AutoZone special as are the wires.
Air filter is K&N but I didn't do anything with that other than smack it on the ground a couple of times to knock off the big chunks.
2 hours ago the truck was running great...
Could that plug gap be the culprit? Everything else is done normal. Wires are all back on the correct spots. I made sure I heard all of them "click" onto the plugs. I rechecked all that.
I unplugged the AFM at the clip (NOT the screws - did that in my MR2 before.. haha).
Don't have a multimeter to test the AFM, but I didn't do anything to it, i don't see how it would have gone bad on me.
I'm stumped.
I'm stumped.
I'm stumped.
I'm stumped.
For anyone else that might have a similar problem, this is what fixed mine.
Apparently there's a little elbow under the air cleaner tube (before it gets to the AFM) and mine didn't line up right and there was a huge gap of un-metered air coming in through there.
Plugged it back up and we're back to kosher.
You were both describing exactly what happens when you get un-metered air in the intake. Usually a crack in one of the intake hoses, or a leak around the junction.
one of the other sources might work out for you too, hope it helps;
Parts/Bumpers/Mounts
4Crawler Off Road: http://4crawler.com/4x4/ForSale/ProductLine.shtml Custom body lifts, Driveshaft spacers, electrical solutions
Addicted Off Road: http://addictedoffroad.com/
TRD PARTS 4 U: http://trdparts4u.com/
4xinnovations: http://4xinnovations.com/
Marlin Crawler: http://marlincrawler.com/
trail-gear: http://www.trail-gear.com/
All Pro Off Road: http://www.allprooffroad.com/
Dave' Off Road Performance: http://www.davezoffroadperformance.com/ Tube doors, third members, driveshafts,etc
Toyota Truck Dismantlers: body parts/axles etc
The Toy Man (newberg, OR) http://www.thetoyotaman.com/
MazToy (troutdale, OR)http://maztoy.com/
Davez Off Road: http://www.davezoffroadperformance.com/
Yotayard (colorado) http://www.yotayard.com/home.htm
Jim's Got Parts (Denver, CO) http://jimsgotparts.com/
California Mini Trucks (Cali) http://www.calminitruck.com/
NIX99 (washington state) http://nix99.com/
Rancho Toyota Truck Dismantler (Cali) http://www.ranchotoyotatruckparts.com/
toy truckc (CA) http://www.toytruckscalifornia.com/
Toy Connection (CA) http://www.toyconnection4x4.com/home.html
All Toyota Truck and SUV (CA) http://www.alltoyotatrucksuvparts.com/
ToyoKings (FLA) http://www.toyokingsusedparts.com/
Yotatech Classifields :https://www.yotatech.com/forums/f91/
TTORA Classifieds: http://ttora.com/forum/forumdisplay.php?f=3
Pirate classifieds: http://pirate4x4.com/forum/forumdisplay.php?f=4
Parts Locators: http://www.autopartslocator.com/
http://www.seekautoparts.com/
Thread on http://www.toyotadiesel.com/forums/showthread.php?t=343 with Parts sources/ links in Cananda & Australia
Sticker Kits
Jame Dean Creations: http://jamesdeancreations.com/ Toyota vehicle sticker reproductions
Sticker Kits
I'm not sure where this thread is going. But I do have some contributions if you're looking for some.
Here's the links page from the wiki. I've been adding to it for quite awhile now. Lot's of part sources there.
https://www.yotatech.com/wiki/index.php/Links
Also here's another Toyota dismantler. Bought a speedo cable from him last week.
If you're looking for used parts the BEST site on the web is definitely Car-Part.com
89 Frunner:
https://www.yotatech.com/members/62565.html
michael1963:
https://www.yotatech.com/members/62594.html
one of the Mods is also from Ontario: Aviator
https://www.yotatech.com/members/1581.html
hope this helps
Last edited by rworegon; 08-14-2014 at 05:49 PM. Reason: remembered some canadian members
Jnkml
07-06-2015 01:20 PM
