3.0 Running rough / No Power after head gasket job
Hope I can get some help. I have a 91 pickup with the 3.0. Just got done doing head gaskets. Started it up, timed it. Replaced timing belt etc. It runs very rough at idle. Low idle ( around 500-600) all new plugs and wires. When I rev it up it just goes dead kinda like a flat spot.
Sprayed all vacuum lines down with carb cleaner, sprayed intake manifolds etc to get check for leaks. No sign of any. No check engine light. No codes.
Checked firing order its good, checked and rechecked all vacuum line routing.
I appreciate the help.
zd92655
03-06-2022 12:58 PM
Spicer
06-10-2020 08:39 PM
voiddweller
19
05-02-2016 09:10 PM
