3.0 rough idle
Codes?
Timing set correct?
TPS within spec?
Vacuum leaks?
Cold Start Timer not shutting off? I am dealing with a bad timer now, but I haven't been able to test it yet. I don't know if the timer would go bad and keep telling the Cold Start Injector to fire.
Timing set correct?
TPS within spec?
Vacuum leaks?
montanatruck
02-26-2017 07:07 AM
