3.0 rear cam seals
3.0 rear cam seals
can the rear cam cam cover or seal be replaced without removing the camshafts? my valve covers are leaking bad, and its leaking a lot of oil from the rear cam plugs too. also, where would i be able to purchase these seals?
One way to purchase them individually, outside of a gasket kit of some sort, would be from a dealership or an online OEM Toyota parts supplier.
My first choice in online OEM Toyota parts suppliers is 1stToyotaParts.com
The part number for those is 11188-65010.
I just looked on RockAuto.com and they have them also. They won't be OEM, but should work just as well.
FEL-PRO Part # ES72308
Camshaft rear seal plug set; Valve Cover
jerusry
10-19-2015 05:28 PM
