3.0 power loss help???
Old 07-06-2010, 05:04 PM
osamabinkeifen's Avatar
i know every one calls this the 3.slow but i swear something is wrong with it. i get only about 150 miles to a tank of gas and there is no power especially under 3500 rpm. sometimes if i ease into the throttle it almost dies and then accelerates reallllly slow.
i have adjusted the tps twice
tested o2 sensor, and whatever the mass air flow meter is called, and checked the vacuum
still havent gotten any codes...i read somewhere the tps can go bad and not throw any codes but im 98% sure i have it adjusted right
the fsm says check the ect (engine coolant temp sensor) where is that?
it only has 120k and i just did the heads and timing belt
Old 07-06-2010, 05:30 PM
t-1hundred's Avatar
http://www.buzzle.com/articles/sympt...on-sensor.html
Old 07-06-2010, 05:32 PM
t-1hundred's Avatar
and if your getting 150miles to a full tank something must be wrong cause i get 250-260miles to a tank and im running a 8inch lift with 35s lol
Sleaker
08-26-2020 06:03 AM
coleypull15
11-03-2015 07:41 AM
tj884Rdlx
08-28-2015 12:04 PM
93toyoguy
08-02-2015 07:41 PM
tobylab
07-12-2015 12:53 PM
Quick Reply: 3.0 power loss help???
