3.0 lIFTERS
Old 01-12-2009, 03:38 AM
FUSOTECH's Avatar
3.0 lIFTERS
Hi guys, got the heads off my '93 3.0. Taking to machine shop today for
resurface. I was looking at the lifters and can't figure out how to get them
apart to look at or measure shims. This type of lifter set-up is totally new to
me.
Old 01-12-2009, 04:19 AM
abecedarian's Avatar
there's a bucket on top of the valve and spring and the shim sets on top of that.
you might want to check this out:
http://www.ncttora.com/fsm/1993/engine/68cylinder.pdf
and here's a 93 FSM:
http://www.ncttora.com/fsm/1993/index.html
Old 01-12-2009, 08:36 AM
FUSOTECH's Avatar
Thanks. I couldn't get the shim out of the bucket, maybe oil holding it. Didn't won't to
get too violent with it. Will try to seperate tonight. Yes,I did lay them out in order.
Old 01-12-2009, 04:39 PM
zlathim's Avatar
Yes, they can be a bit of a bugger to seperate, but they do come apart.
Old 01-14-2009, 04:24 AM
FUSOTECH's Avatar
Messed with the lifters abit and got the shim out. They can " be a bugger ". Now that I
see how it works,valve adjustment should be easy - just time consuming.
91yotapup
3.4 Swaps
03-05-2019 10:41 AM
scott90
10-04-2015 09:21 AM
Jdgarrison
10-01-2015 05:22 PM
Jdgarrison
10-01-2015 02:11 PM
93RedKrawler
09-29-2015 02:50 PM
Quick Reply: 3.0 lIFTERS
