YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-12-2008, 09:08 PM   #51 (permalink)
Green93's Avatar
Send a message via MSN to Green93
I avoided this thread for quite awhile just because of the title. Just tired of reading 3.0 bashing threads. I'm pleasantly surprised to see that most of the responses are positive.
I myself have a love/hate relationship with my 3.0. She is plenty strong for what I need. If I had to haul stuff I would have gotten a fullsize truck. If I wanted to beat everyone in the stoplight races I would have bought a supra(I wish). The engine is good for what it was designed to do. My only complaint is that she is a little thirsty. I get an average of about 15-16mpg. 13mpg if I have that handy little ECT button pressed the whole time.
Jason
__________________
1993 Toyota 4WD Ex-Cab
Auto
31 10.5 15 BF Goodrich A/T's
Front and rear diff. breathers
Aisin manual hub swap
Clarion Pro Audio CD player
MB Quart speakers
3VZ-E V6 with fresh rebuild:
Block bored 20 over
Engnbldr master rebuild kit
Heads rebuilt
Engnbldr 1mm o/s valves
Weasy2k stage 1 cams
Cleaned and balanced injectors
LCE ceramic street header kit
LCE pro flow exhaust with cat delete
http://picasaweb.google.com/Green93Toy/MyToy#
Green93 is offline
Sponsored Links
To remove this ad, register today!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
bad rings or bad valve stem gasket? co4rnr 86-95 Trucks & 4Runners 26 11-16-2007 08:59 PM
bad rings or bad valve stem gasket CONCLUSION! co4rnr 86-95 Trucks & 4Runners 0 11-16-2007 12:23 PM
Bad gas mileage (bad catalytic converter?) Help!! zberch 95.5-2004 Tacomas & 96-2002 4Runners 4 07-15-2007 11:08 AM
low voltage under load - bad alt. vs bad ground CILO 86-95 Trucks & 4Runners 3 02-12-2007 11:49 AM
Bad Valve Bad clutch Is it easier to pull engine? jjenks0 86-95 Trucks & 4Runners 10 03-01-2006 12:45 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
