3.0 Head Gasket
Old 02-09-2009, 10:22 AM
Oldmans4x4's Avatar
3.0 Head Gasket
I am in the process of buying a head gasket set, which company do you recommend? Ebay? Thanks in advanced for the help and insights.
Old 02-09-2009, 12:27 PM
Matt16's Avatar
OEM (Toyota) is good but I'd assume expensive, heard good things about Felpro (Federal Mogul ?) which is what I'm using on my 22RE engine.
Old 02-09-2009, 12:36 PM
GSGALLANT's Avatar
The best I've heard of (other than Toyota) is from ENGNBLDR (I think that's how it's spelled). Do a search on here for more info. When I did mine, that's the kit I used and had no problems.
Old 02-12-2009, 08:43 PM
302Toyota's Avatar
im a mechanic for toyota and i have 3vz also and just had the same problem ..i used felpro the first time and some other off brand the second time then the 3rd and final time i used toyota gaskets ..toyota updated there head gaskets and i have yet to have a problem with the OEM Gaskets so now if i ever have any engine prblem with a toyota engine i wont use anything but OEM gaskets they may be more expensive but its better to do it right the first time ..also replace head bolts when you do head gaskets
kgcwb44
01-29-2023 10:02 AM
the1998sr5
15
07-14-2020 08:35 PM
Colington
03-08-2020 09:51 AM
09-04-2015 09:27 AM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: 3.0 Head Gasket
