3.0 cam advance?
Old 04-24-2009, 01:53 PM
mikhail's Avatar
3.0 cam advance?
I was wondering if it would be possible to gain more high end power from the 3vze by advancing the cam shafts about a groove or two on the timing belt? Im trying to get more power from about 3,000rpm and up. I know this could make it a bit slower below that but I dont really care cause I always have it floored anyways. anyone ever tried it?
Old 04-24-2009, 02:50 PM
TNRabbit's Avatar
Don't bother. It's made to run pretty much where it's at. You can advance the timing 2 more degrees & run premium unleaded.
Old 04-24-2009, 04:11 PM
mikhail's Avatar
you mean ignition timing right?
Old 04-25-2009, 05:35 AM
TNRabbit's Avatar
Yep, ignition timing.
Old 04-25-2009, 06:45 AM
mikhail's Avatar
Its throwing the knock sensor code, even though ive replaced the sensor and the pigtail harness. I havent actually put the sensor in the stock location though, its just sitting on the intake manifold.
I think the ecu will retard the timing though without the knock sensor right? Cause I have the distributor set all the way advanced, it runs best like that, ive tried turning it back a bit but it starts pinging. Ive been running 87 octane though, ill try premium next time.
tobylab
01-18-2016 07:06 PM
coleypull15
11-03-2015 07:41 AM
129Creepin
08-05-2015 10:12 PM
britishdudes2dr
07-25-2015 06:47 AM
tobylab
07-12-2015 12:53 PM
Quick Reply: 3.0 cam advance?
