| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#26 (permalink) | |||||
#27 (permalink) |
Sean, on this AC part of that thread:
"A/C Solution: You need the electronic card from the 3.4L A/C cooling unit located behind the glove box in the donor vehicle. With the 3.0L configuration the card receives a signal from the negative side of the ignition, in order to work now it will now need to receive a positive signal from the ECU instead. You will need Toyota wiring diagrams to figure this one out." Is the electronic card needed if you keep the 3.0 AC system in place and just swap out the compressor? That is what I was planning on trying if I can get the old 3.0 compressor lines to connect to the 3.4 AC compressor. Thanks
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. |
#28 (permalink) |
yes i would like to know about the ac as well. I read you can keep the 3.0 ac in place you just have to change something.
__________________
1992 4runner SR5 OME HD springs, OME shocks and struts SDORI BJ Spacers Superwinch Hubs 31" BFG's |
#29 (permalink) |
You can keep the 3.0 AC I believe with some modification. The one thing we never bothered to finish was the AC since some components needed to be replaced and it needed a charge anyway. Plus the owner of the truck lives in a fairly temperate place that never goes above 85° or so. One YT member who did a 3.4 swap early on gave me the info about the AC cooling unit. If you search you will find more recent info on that I'm sure.
I can verify the tach fix as I did that and it works perfectly. Same goes for everything else. Also since we did our swap ORS now offers a beautiful exhaust cross-over pipe so that takes care of one of the hardest and potentially most expensive parts of the swap. Last edited by SEAN_at_TLT; 03-27-2006 at 09:47 AM. |
#30 (permalink) | |
Quote:
http://community.webshots.com/photo/...42310107mrSdec http://community.webshots.com/photo/...42310107vKoMhx
__________________
#31 (permalink) |
Hey Sean, nice write-ups in Off-Road mag on the 3.4 swap! I just got my June issue and you mention that you were able to use the 3.0 cruise control. That's great because I was wanting to do that too. How do you get the cable to hook up to the throttle body?
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. Last edited by mt_goat; 04-07-2006 at 03:36 AM. |
#32 (permalink) |
Thanks for the positive comments! It's been nearly two years since we finished the swap so the finer details are not so fresh in my mind. It seems to me all we did was attach the old cable to the 3.4 TB. I'll have to check my notes and get back to you, otherwise it should be covered in next months issue of Off-Road.
#33 (permalink) | |
Quote:
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. Last edited by mt_goat; 04-10-2006 at 05:14 AM. |
#34 (permalink) |
I just got the May issue and was unaware that the June issue was already on newstands. I'll check my original notes and get back to you soon about the cruise control.
#35 (permalink) | |
Quote:
__________________
#36 (permalink) |
Okay, I couldn't find anything specific in my notes but after thinking about it some more it seems to me that all we did was attach the 3.4 cruise control cable to the old (3.0) cruise control mechanism and then do the same with the vacuum lines. I was so easy that I don't think we even bothered to note it.
I suppose there could be a way to retrofit the 3.4 cruise control mechanism but we didn't bother since using the old unit was so simple and after testing it on the freeway it was also effective. I drove to LA from the Bay Area on I-5 (300 miles) and used cruise most of the way with great results. |
#37 (permalink) |
Thanks very much Sean. I'll look at the two together again. The first time I looked it seemed like the CC end of the two cables were different. Yeah, I don't want to use the 3.4 CC if I can help it.
__________________
| Tags |
| 30, 34, engine, swap, toyota |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Newbie 3.4L engine swap questions | Belize Off Road Team | 86-95 Trucks & 4Runners | 6 | 07-17-2007 01:25 PM |
| Engine Swap Questions | Leprechan | 86-95 Trucks & 4Runners | 8 | 10-17-2006 11:29 AM |
| 22RE cylinder compression/ engine removal and swap questions | the4x4runner | 86-95 Trucks & 4Runners | 6 | 07-25-2006 03:48 PM |
| 3.0 engine swap questions | special k | The Fab Shop | 13 | 11-24-2005 12:05 AM |
| engine swap questions | Freddy Neel | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 01-18-2005 08:43 PM |
