| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
2wd rear - too stiff
#2 (permalink) | |
Well, you don't want to bottom out. Hmm... I know a lot of the 4x4 guys are modifying the spring mounts and running Chevy 63" springs. A longer spring will translate to more flex/easier flex. I assume this would solve your stiff problem. Check out the Chevy spring on Toyotas FAQ over at Pirate to see if you might want to tackle something like this.
Specifically this statement in the FAQ: Quote:
#3 (permalink) | |
Quote:
Was on one trip with a guy who just got a 4WD Toyota pickup. He had found the rear springs were too stiff and too out the overload. He had a very soft, flexy ride. But at the first steep climb on the trail were were on, his rear axle hopped once (axle wrap) and he now has "S" shaped springs, axle riding on the bumpstops and those springs were toast. The overload does help protect the rest of the springs from overloads, both in direct vertical loads, but also in terms of excessive torque to the axle.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#4 (permalink) |
So...
I took out the overload leafs and put in an add-a-leaf. The add-a-leafs I used were originally in a Ford Ranger (spring over). I put them right in the place of the overloads. The ride is a lot nicer and I got about 4 inches of lift. I definitely have more travel now and will need to get some longer shocks. Anyone considering a lift shackle, should definitely do this instead. Last edited by Travisfab; 11-30-2007 at 08:32 AM. |
#5 (permalink) |
Just a little update on this. The ranger add-a-leafs worked great, but it had my truck sitting ass high. If my front end was lifted more around 6 inches, it would have been perfect. So what I did was cut 6 inches off either side of the add-a-leaf, so that it had less arch. Re-installed and I am sitting with about 2 inches of lift over stock, which is perfect for my application. I definitely need longer shocks now, my shocks top out before I get all of the droop travel my truck is capable of.
#6 (permalink) |
Yes, adding an add-a-leaf can help improve the ride, at least if the ride was stiff due to the old springs sagging onto the overload leaf. Since the AAL can flex more than the super stiff overload leaf, you now have a spring pack that can flex.
__________________
#7 (permalink) |
Exactly,
I tried it out for about a week without the overload or add-a-leaf and I was bouncing off the bump stops all the time. I like to do suspension modifications that actually do something. A shackle, or lift spindle for example, do nothing to improve your suspension. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Rear Locker while in 2WD | ISurfer88 | FJ Cruiser | 0 | 03-07-2007 07:12 PM |
| 2wd rear axle vs. 4wd rear axle (newbie warning) | fustercluck | 86-95 Trucks & 4Runners | 3 | 08-08-2006 03:05 PM |
| Rear differences between 2wd and 4wd | hbar314 | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 04-13-2006 06:53 AM |
| How stiff are daystar rear-add-leafs? | baileymoto | Offroad Tech | 2 | 05-05-2005 08:52 AM |
| Will a 97 4x4 rear diff fit a 1997 2wd rear? | blown2wdtoy | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 09-22-2004 01:40 PM |
