2wd rear axle vs. 4wd rear axle (newbie warning) - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-07-2006, 06:41 PM   #1 (permalink)
Sponsoring Member
fustercluck's Avatar
I searched the forum and didn't find an answer to this question, so if this is annoyingly newbescent, toughski.
Is the 2wd V6 rear axle the same (fungible substitute) as the 4wd V6 rear axle? I need to know kinda quickly. Anyone?
__________________
War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself.
John Stuart Mill
English economist & philosopher (1806 - 1873)
fustercluck is online now
Old 08-07-2006, 10:10 PM   #2 (permalink)
stock87's Avatar
Send a message via ICQ to stock87 Send a message via AIM to stock87
Don't know how much this will help, but...
I'm not sure if it was limited to engine type or what anymore. My friend has an 89 2WD 22R(carbed) that has the 8" Diff and it's 4-pinion from the looks of the case. That said, I have no idea if it's the original, but I suspect it is due to the fact that it was the original timing chain we changed out at 275k.
Obviously the biggest problems will be the gear ratio (3.73 in the case of my friend's truck) and the axleshafts only being 5 lug. Otherwise, I suspect the housing will work in the usual suspects.
__________________
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
stock87 is offline
Old 08-07-2006, 10:18 PM   #3 (permalink)
Staff
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
Except the 2wd is a spring under, and the 4wd is spring over.
4wd uses a lever style E-brake, 2wd uses a cable that runs 1/2 way up the truck on each side
2wd is 5 lug, 4x4 is 6 lug
2wd uses smaller brakes (10" i think?), 4wd uses 11" brakes
BTW. If you are talking 4Runner, then yes. 2wd is the same as 4wd. My info is about the trucks.
__________________
Tacoma miniheader install kit Now available! Click here for ordering information
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by space-junk View Post
DeathCougar, you know everything!
Quote:
Originally Posted by fustercluck View Post
Now I know DC is a leader.
DeathCougar is offline
Old 08-08-2006, 03:05 PM   #4 (permalink)
Sponsoring Member
That's what I was looking for. Thanks guys. I appreciate your time.
__________________
John Stuart Mill
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
where for custom rear axle? 2wd 1jz p/u str8_6 The Fab Shop 7 02-20-2007 06:57 PM
Rear Axle Rubbing noise = damaged axle? Badmice1 95.5-2004 Tacomas & 96-2002 4Runners 5 12-06-2006 11:08 AM
85 4wd t-case & rear axle to 89 4runner? bourgason 86-95 Trucks & 4Runners 4 08-28-2006 11:17 PM
taco 2wd non trd rear axle(5lug) TSLBOGGGER 95.5-2004 Tacomas & 96-2002 4Runners 4 03-07-2006 09:08 PM
Need a rear axle for 99 4runner 2wd pruney81 95.5-2004 Tacomas & 96-2002 4Runners 5 12-25-2005 07:44 PM
2009 InternetBrands, Inc.
