2wd oil pan with SAS
Old 02-27-2010, 07:55 AM
Dipstik_90's Avatar
Can you use a 2wd 22re oil pan in a sas truck?
Old 02-27-2010, 08:15 AM
tc
tc's Avatar
Yes, IIRC it's preferred actually because the sump is in the rear providing more clearance for compression travel.
Note that when you change front sump to rear sump, you need more than the pan - the pickup/snorkel and dipstick are different too.
Old 02-27-2010, 08:31 AM
Dipstik_90's Avatar
I have everything. The engine I got to rebuild was a 2wd and I really don't want to buy a new pan. The sump on my 4wd was right at the rear and this one is more towards the middle.
Old 02-27-2010, 08:35 AM
tc
tc's Avatar
I must be thinking V6's - you want the rearmost sump.
Should be easy to swap over, especially if you have both motors side by side.
09-04-2015 09:27 AM
thefishguy77
07-30-2015 10:59 AM
irritech
07-27-2015 05:15 PM
yourrealdad
07-21-2015 11:13 AM
colasurdo
07-16-2015 11:37 AM
Quick Reply: 2wd oil pan with SAS
