Sign in using an external account
| 86-95 Trucks & 4Runners 2nd/3rd gen pickups, and 1st/2nd gen 4Runners with IFS |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
__________________
1991 Pickup 22re 2 Wheel Drive.
F: Fabtech UCA's, Obsessed spindles, sway away torsion bars R: Shackles, OME springs Bilstein 5125's, 4WD front fenders and grille, DT Header, Supra AFM, 31" BFG A/T's, Hella E-Code's, Hella 500's, LCE short shifter, Optima Red Top, 4.56 gears, Detroit Truetrac, ENGBLDR timing chain kit, Full Dynomat. 135,000 miles running strong! |
#2 (permalink) |
Vendor
Sales Rating: (0)
Why are you lifting a 2wd? Looks? Prerunner?
I would either put long travel on it or slam it and make it fast, show the honda fan boys whos boss
#3 (permalink) | |
Vendor
Sales Rating: (0)
Quote:
it will cost $5,000+ be "fast" and thats still not that fast (14 second 1/4 mile?) |
#4 (permalink) |
Personal
Sales Rating: (0)
Batchracing has an economical 2wd LT kit that uses your existing spindles. That's what I plan on going with for my 2wd.
__________________
Dr. Evil Somewhere in the pile of parts in my shop there is a '88 Shortbed P/U, 22R, 2wd, 4spd manual, no bed, cheap shocks, IFS w/o sway bar, rest stock. 223k km (~138k miles). Check out my 2wd 5-lug 8" axle rebuild! (in progress) My First-ever Fab Project: Flatbed |
#5 (permalink) |
Personal
Sales Rating: (0)
[OP]
The main reason for the added lift is to increase downtravel b/c with my current lift I only have 2" of downtravel which is ˟˟˟˟! My UCA's are constantly hitting my bumpstops. Adding taller spindles will help alleviate this problem. I am also running 31" tires that rub on the firewall occasionally and the added lift will help correct this problem. Lastly I need new Balljoints anyway so if I am going to put lift spindles on, now is the time.
I don't feel like I need to go the LT route because I don't wanna drop $3,000 more on my DD that doesn't see THAT much offroad use. I don't wanna try and match paint on the flared fenders that I would have to install. I just want a clean DD that can go wherever I need it to. Nothing too crazy, I'm not gonna go rock crawling or jumping or thick sand.
__________________
#6 (permalink) | ||
Vendor
Sales Rating: (0)
Quote:
Which doesnt need to cost anywhere near 5k.Quote:
#7 (permalink) |
Personal
Sales Rating: (0)
key word here is Economical...
I say look at Batchracing...just like Magnusian said! never heard of them, but theres a lot of companies that aren't well known that produce top quality products! yes..motor swap ....7MGTE say what!?!?! or maybe a 2JZGTE? heck even a 5mg would be nice lmfaome personally, i would probably make it fast..but everyone has different opinions ![]() instead of looking into lifts (which prolly wouldn't help AS MUCH as this) look into a locker for the rear!!! if you were locked in the rear....and say some 31" swampers in the rear..you could prolly go a lot of places a stock 4wd rig won't...you'll just have to go balls out, 5,000rpm lmao
__________________
I'm Roalin' Coal now. 2001 Dodge 3/4 ton cummins, 6speed, QCSB, 35's on 18's, straight piped, cattleman front bumper. CAI, and superchips tune. |
#8 (permalink) |
Personal
Sales Rating: (0)
i seen a D-Stroked 327 chevy V8..it has a 283 crank and some different rods...
the D stroked design allowed it to turn well over 10,000rpms....that'd be a fun motor to have in a toyota
__________________
#9 (permalink) | |
Vendor
Sales Rating: (0)
Quote:
I read through many threads for a couple hours a couple months ago, all on various forums, and there was a slim number cases where someone had something good to say about him, they all had some sort of complaint. So IMO stay away from BatchRacing, and spend the extra cash to go with a total chaos kit so that you know you wont get screwed. |
#10 (permalink) |
Personal
Sales Rating: (1)
x2 on what 2DoorRunner said. Nate at batch racing has not only ripped alot of people off and they are looking for him but he also couldnt weld or fab worth a crap and some of his kits were falling apart after a little offroad usage.
yakerat, i would go with the obsessed spindles. i have seen a pair in person and they good for what they are. i have also talked to a guy on dezertRangers and he has used them on his truck and jumped the crap out of it with no problems. i was going to order a set back when i had my old fabtech ivan dan kit but they would have run 1/2 the price i found my total chaos kit for so i went that route. there used to be a guy on DR and on TTORA that made lift spindles but they were kind fugly and i dont think i would have trusted them. with the fabtech ones if you can find them, you have to worry about the steering arm ripping off the spindle and leaving you stranded on the side of the road which is a known problem with them.
__________________
94 pickup: Std Cab, 22RE, 5spd, 2wd Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover Shocks, Custom Engine Cage, Hannemann Fiberglass Fenders |
#11 (permalink) | |
Personal
Sales Rating: (0)
[OP]
Quote:
Already locked in the rear with a detroit trutrac, and I love it! No more one wheel peel for me!
__________________
F: Fabtech UCA's, Obsessed spindles, sway away torsion bars R: Shackles, OME springs Bilstein 5125's, 4WD front fenders and grille, DT Header, Supra AFM, 31" BFG A/T's, Hella E-Code's, Hella 500's, LCE short shifter, Optima Red Top, 4.56 gears, Detroit Truetrac, ENGBLDR timing chain kit, Full Dynomat. 135,000 miles running strong! Last edited by yakerat; 08-28-2010 at 08:22 AM. |
#12 (permalink) | |
Personal
Sales Rating: (0)
[OP]
Quote:
Do you know of any beef lift shackles? I know brian (beefed taco) makes them but I bet he charges an arm and a leg. Is there any companies out there that make quality lift shackles?
__________________
#13 (permalink) |
Personal
Sales Rating: (1)
with downey being gone i dont know off the top of my head. they are the ones that i had. but if i remember right i think (but not 100% sure) the 4x4 and 2wd used the same shackles or ones really close so you might be able to get away with buying some 4x4 ones. if anything i would give roger at 4crawler a call and give him the measurements of a 2wd and see if they would work.
http://www.4crawler.com/4x4/ForSale/Shackles.shtml http://www.trail-gear.com/shackles
__________________
#14 (permalink) |
Personal
Sales Rating: (0)
[OP]
Ordered shackles from trailgear. I looked EVERYWHERE and trailgear had the cheapest greasable shackles since I will be running poly bushings. Also got some extended brake lines. Get this though I tried to order Obsessed Spindles and they told me they are going on vacation for 2 weeks and can't start making them until they get back.....Kinda bummed....lagging....
__________________
| Tags |
| 1994, 2wd, cheap, chevy, fabtech, lift, lifted, motorsports, obsessed, pickup, raised, spindle, spindles, toyota, uca |
