2wd BJ's! spacers that is lol...
Old 01-27-2009, 04:41 PM
needsomecam's Avatar
I am wanting to level my truck- 89 2wd dually
by staying with ifs and getting ball joints spacers is it safely possible to get 3 inches of lift?
i just wanna level my truck for cheap but safe.
Is 1.5 inch blocks the tallest you can buy? (from here : http://www.4crawler.com/4x4/ForSale/...ntSpacer.shtml) is there a 2 inch block? obviousley cv angle doesnt matter its a 2wd but help me out here lol
thanks
Old 01-27-2009, 07:58 PM
Matt16's Avatar
CVs are only half the battle. Steering is a big issue. With 2wd-size tires and primarily on road use (right?), that may not be an issue.
Steering is not an issue, then the limits are going a)the ride comfort and b) the limits of the alignment cam bolts.
Old 01-27-2009, 08:08 PM
abecedarian's Avatar
With 2wd, you don't have CV's to worry about. Also, 2wd alignments are done with shims on the upper control arm, not cam bolts like the 4wd trucks... (sorry Matt16).
What you end up dealing with are the 'struts' from the front cross member back to the lower control arms: they are only "SO" long. With too much lift, the struts can't get longer and cause the LCA to be pulled too far forward, wreaking havoc with caster and camber... not to mention the LCA bushings. 3.5" lift is about the most you can get away with before they become a problem.
A bit more pricey, but more friendly with levelling your truck out since they don't affect geometry as much as BJ spacers, LT kits or even cranking the t-bars...: lift spindles- http://obsessedmotorsports.com/toyot...d_spindle.html
Old 01-28-2009, 10:25 AM
but since i dont have $500 will the BJ spacers work?
Old 01-28-2009, 03:23 PM
Well... the spacers will work but you're gonna be limited in how much lift you get by the size of spacer (typically 1.5-2").
Basically they install like the 4wd spacer, but you will have to crank the bars up to get the lift. You have to do that with the 2wd since the torsion bars act on the lower arms, not the upper arm like the 4wd trucks, so installing the spacer moves the 'loose' upper arm up, not the sprung lower arm. Make sense?
The struts I mentioned won't be an issue with the spacers or with the spindles, or with a lift up to about 3.5". At least they're not an issue on my 91 with the (discontinued) Fabtech 3.5" lift... speaking of which maybe hit up ebay or craigslist and see if anyone's selling one. They are still out there and I bought the one for my 91 for 400 bucks.
Old 01-28-2009, 04:57 PM
PirateMcgee's Avatar
they make 2" llft spindles for 2wds
Old 03-02-2009, 10:59 AM
Armytaco's Avatar
I have some brand new 2wd BJ spacers I will sell you for $75. I got them from 4 crawler and never installed them. Now I dont need them and have them. Let me know. Armytaco@aim.com
Old 03-02-2009, 04:36 PM
Robert m's Avatar
i dont get this. when i had stock suspension and i installed my spacers, it gave me lift. then when i cranked the torsions, i got even more. so why did they work on my truck?
Old 03-02-2009, 06:39 PM
jmcgowan's Avatar
I bought some 4Crawler BJ spacers (1.5"), and I was thinking about buying some of the Obsessed 3" lift spindles, is that too much for a 2WD ? Does anyone know if I'm going to need longer brake lines ? (and where to get them if I do ?)
ladybugRC
458
08-21-2020 10:41 AM
Dale Johnston
11
10-31-2015 10:22 PM
Flightguy
10-02-2015 05:34 PM
Cycles
09-29-2015 06:37 AM
crash813
09-27-2015 07:15 AM
Quick Reply: 2wd BJ's! spacers that is lol...
