2ndary cooler
2ndary cooler
i am buying a secondary cooler off of a fellow yotatecher. My 4runner is an 88 so i have to remove the blank from the block and i already have the water pump with the outlet pipe. My question is, were does the return go? is there a fitting i need for the block or does it T into an existing water line? Any info would be great, Pics would be even better. Thank in advance all!!!!
This is a lousy pic, but it looks like the top hose routes right into the block.
You can just make out where the dip stick guide plugs in...I don't know if that is the supply or the return, but which ever it is, it appears to be between the #4 and #6 cylinders.
I don't have any of the clamps that are in the pic, and don't worry, this is not the one I'm sending. The one in the pic is on an old engine long gone.
can you post a diff. pic? That one i cant " blow up " to get a better look, btw i should be sending you money tomorrow, and yes i believe it will fit in a it fits it ships box.
kawazx636
10-06-2021 03:03 PM
scott90
10-04-2015 09:21 AM
runnermedic
13
09-21-2015 05:20 PM
FS[NorAtl]: FS: NYC 1987 4x4 22RE Engine and Auto Trans
TransAmBandit
09-20-2015 06:08 PM
