2nd gen squealing belt
Old 09-12-2005, 02:27 PM
Y2Krunner's Avatar
My 4runner never squealed at all. one day i went offroading and it came bcak squealing. everytime i started it it would squeal for 30 seconds or until i reved it up. i replaced the alt belt and checked to make sure the alt bearings were spinning freely and all seemed fine. things were quiet until next time i went offroading and now it squeals the same it did before. could the belt be slipping off the pulley until it warms up a few seconds later? im pretty sure i tightened it as neccesary. i have replaced all sorts of belts on vehicles and never had this kind of trouble. any info would be greatly appreciated
Old 09-13-2005, 05:14 PM
Beartracker's Avatar
Sounds like it to me. Try to tighten it a little more when it's warm.Mike
Old 09-13-2005, 05:29 PM
4Crawler's Avatar
A new belt can stretch after you first install it. I find I need to snug up the belts, especially the alternator belt 2-3 times after installing a new belt before it settles in. You might also check all the pulleys on the belt see if any have any oil/grease/dirt on them.
Old 09-13-2005, 05:55 PM
Y2Krunner's Avatar
would WD-40 on the pulleys cause them to slip everytime? is it possible for dirt to get embedded in the belts causing them to squeal when cold?
Old 09-13-2005, 09:39 PM
4Crawler's Avatar
WD-40 is oil, oil is slippery and makes things slip. Rubber v-belts want to be clean and dry to work the best, they operate on friction. If the blets slip too much, the surface can become "glazed" and that can also cause squealing.
lmobeats18
08-28-2015 04:57 PM
izzmee
08-17-2015 10:20 AM
vanion2
07-29-2015 06:17 PM
PlayAwhile
07-20-2015 11:36 AM
Steezy96yota
07-06-2015 10:00 AM
Quick Reply: 2nd gen squealing belt
