Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
2nd gen proven engine mods ??
i realize that most mechanics will tell you that there isnt much you can do to help the performance of a stock 3.0 v6...besides swapping it out...without going that drastic...what have you guys found that actually works to get a little more power from this engine...
__________________
'95 Runner, Downey HD Coils, Bilsteins, K&N air filter, airbox mod, Yakima roof rack, Sony Mobile ES and MTX system: head unit/10 disc changer/eq/speakers/subs/amps |
| Sponsored Links |
#2 (permalink) |
Driving one of these in stock form is like driving a tank. I went from a fast Accord to one of these and just about returned it. So far I have put a flowmaster 40 with 2.5" pipe cat back and a K&N FIPK. Now the truck can get out of it's own way but I'm looking to put on some headers. So far I have only found two companies that make them for this engine, Downey and Northwest Off-Road. From what I hear the stock exhaust manifold on the trucks is one of the most restrictive designs ever made. I still get the serge of power around 3K and I've read that the headers are suppose to bring that power down to more driveable RPM's. 3 to 5K isn't a big enough power band for me. Also I have been contemplating a chip at some point but I have been told that you should finish most of your major mods before since they calibrate the chip for the mods. And you only want to have to sent it in once.
#3 (permalink) |
I build my own headers and used a K&N filter. And a larger exhaust, no cat and a free flow SS muffler.
That gave me a very noticeble improvement. I guess at least 15 hp. All other mods I performed had no noticable affect. But it still was no powerhouse so I immediately performed a swap after (another) head gasket faillure. And don't even try to port the heads. It's a job you cannot do yourself, this really needs to be done by an expert. If you add up all the cost of the parts needed for tuning the 3VZE, you might reconsider an engine swap. It's not that pricy if you think that after my supra swap, my fuel economy was 20% better with 55hp more! That swap was cheaper than repairing my busted 3VZE also!
__________________
'90 4R 2JZ-GE swap, headers, turbo and intercooler FR and RR LC axles coils and discs all around AllPro parking brake 305/70 R16 Yokohama MT 4.88 gears |
#4 (permalink) | ||
Staff
Intake and Exhaust are the two big ones. Other things you can do are an electric fan, manual hubs, and a slight timing tweak to 12 degrees instead of 10.
__________________
2006 Tacoma TRD offroad 4.0 Access Cab 6 sp 3" Revtek, 285 BFG's, Borla Catback, Volant Intake, Billet Grill, Split Second PSC1 Professionally dyno tuned, URD Short Shifter Kit, 226 RWHP 1994 4-Runner SR5 5 Speed SASed, Detroits, Armored, Dual Cases, 37" MTR's See my build up thread here http://www.yotatech.com/showthread.php?t=104000 Quote:
Quote:
#5 (permalink) |
Do a search for some of the info. listed in the performance section of UK's signature. You can also find write-ups in the Tech forum.
__________________
1992 4Runner SR5 4WD, 170k, Automatic, 3.0 V6, 31x10.5 BFG AT's, Aisin Manual Hubs, Airbox Mod, OME Stabilizer, ISR Mod, Downey HD's, Bilsteins (Rear) |
#6 (permalink) | |
Quote:
The only vehicles that chip mods are good for are turbo'd (with boost regulated by the ECU), or vehicles that need the Rev Limiter removed (to go an MSD set up or similar) or speed limiter removal. Total waste of money IMO. |
#7 (permalink) | |
Quote:
__________________
#8 (permalink) | |
Quote:
#9 (permalink) | |
Quote:
I garantee you will spend some good time on his site. Very informative. |
#10 (permalink) |
I saw improvements when I installed a hiflow cat, replaced the fuel filter, and did the FIPK.
The FIPK had a strange effect. Normally the 3vze seems to make a LOT of torque the colder the air temp is. The converse was also true, if the air was 100-120 degrees the truck had literally NO power whatsoever. The FIPK changed that - slightly less power when cold (below 80 degree), but a WHOLE lot more power when very hot (100+). Helped gas milage just a touch too and improved top end speed by 3-4mph. All in all I'm happy with the FIPK except for the price. If you have a 3rd gen dont do the FIPK, you loose hp... Electric fans, 2.25" exhaust and headers supposedly work wonders as well as synthetic motor oil... Gadget - would putting in a different thermostat to keep the temp down + electric fans be an effective ECT mod?
__________________
3vze, 4x4, sr5, 90, auto, LSD 2x dB Drag World Finalist 2003 Nopi Nat. Street B champ 2004 SBN Street C champ 2004 SBN Advncd NW Champ 2004 Former WR Holder in NW. SPL: 159.8db @ 42hz In loving memory of Jamie Riggs 5/15/85 - 10/8/04 |
#11 (permalink) |
I just got mine, don't have exact figures, and it might sound too practical, but I did the following as a tune-up and it was like a brand new truck.
spark plugs / wires oil change / oil filter new fuel filter new air filter airbox mod (just took the cone guard off that sat in front of airbox) throttle body cleaning replace torn/worn vacuum hoses new radiator / fluid (i recycled the factory one for $28) complete engine degreasing (just for looks..) and finally, save the best for last.., SEAFOAM I checked the engine after each tune-up 'element' and the Seafoam did the best treatment for me. I just poured 1/3 bottle into the crankcase for three nights in a row and saw a drastic difference. Of course, it probably was the combination of everything, but i'm partial to the seafoam. Also, I did the seafoam after the new spark plugs and checked them to see if it made them dirty or bad, they were still shiny. Anyways, I agree that headers, and intake/exhaust manifold mods will do the best for you, 3.4 swap being better, and so on.. but to do it like I did on a budget, you should be okay.. I'd rather spend my money modding accessories, if my engine is running just fine. It ain't no speed machine and never will be..! Good Luck,
__________________
95 4runner 3.slow..Seafoam drastically improved everything (crankcase only)..165k miles..airbox mod..HD&Satellite Radio..coming soon: indiglo gauges and visor upgrades Last edited by Bubba Wilks : 05-18-2008 at 09:31 AM. |
#12 (permalink) |
FYI: A friend of mine has a 95 iirc with the magical 4.88 gears and 31's, that sucker was easily able to keep up with me in my 3.4L T100 and another friend in a 97 runner with the 3.4L. heck, he may have actually been faster than us on hwy driving!
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks. Currently needing tires, rims, axle shafts, etc. PM me if you have axle shafts!! Be polite. Be professional. But, have a plan to kill everyone you meet. |
#13 (permalink) |
Mine with the 31's and 4.56's doesn't seem that bad to me. I know its not a speed machine, and i didn't buy it to drive fast. I did however bump my timing to 12 degrees instead of 10 and that seemed to help!
__________________
-Mike 1990 4runner SR5, 3.0 with 250K, 5-speed, 4.56 gears, warn premium hubs, Hella 500's, Rancho 9000's, 33X12.50's crappy dunlop tires, rear lock right, 4" trailmaster lift with lc coils in rear Soon to come: New wheels and tires, Sliders, CB. One Day: 3.4 swap! |
#14 (permalink) |
Where in the world did you come up with 15HP ?
15 HP where, at what RPM ? What does 15HP feel like (note, you can't tell me because you don't feel HP, nor do you measure HP). These days the notion of HP is becoming a little bit meaningless. ![]() Fred |
#15 (permalink) |
That's easy.
Mine had 150 hp and a max speed of 160 km/h. Afterwards it did 175 km/h, so, bare with me on this, 160:150=1.0666 and 175:1.06666=164.06 164.06-150= 14.06 O crap, your right, I miscalculated.But seriously, I had no means of measuring the hp, except maybe my calibrated ass, but me and my friends found that the 4R was faster in accelleration and top speed. Most gains were at mid through high rpm's. And yes, most gains will be torque. I do not know what you mean with "you can't feel hp". Feel free to come over and drive my 4R with the 2JZ swap. If you cannot feel that amount of hp gains you're most likely dead. Roger
__________________
#16 (permalink) | ||
Staff
Wow a 5 year old thread and you still burned him ... sweet
__________________
Quote:
#17 (permalink) |
Interesting advice about the K&N... I might try that next time I have to change the filter (have a while though..)
Lets hope I can get a 3.4 in there before it gets too old...
__________________
'95 4runner 3.0L | 192,xxx | ISR mod | Polk Audio Speakers | 31inch tires REAR ENDED AND TOTALED. Got $5,100 for it. link |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 2nd gen cheap mods | lesha30 | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 12-11-2003 06:22 AM |
| 2nd gen interestind mods | 95_4X4Runner | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 10-03-2003 08:06 PM |
| HELP 3rd gen engine swap in 2nd gen ANY INFO ANYONE? | puffy | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 09-25-2003 08:44 PM |
| 2nd Gen Check Engine Light | AlixTheRunner | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 02-25-2003 07:00 PM |
| Engine noise from a 2nd gen V6: | KraTOR | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 12-09-2002 10:10 AM |
