2nd gen overheating problems
Old 07-31-2012, 08:16 PM
ignition's Avatar
hey guys so my 4 runner has had problems with overheating for a while. First it was a bad radiator cap so i replace it and then after the radiator developed a small leak.
i replaced the radiator a couple days ago and have burped the system 2-3 times
so when i burp it and idle it w/o the radiator cap on it hold temp in the middle of guage fine.. but when i put the cap on it will slowly overheat.
is this because of the radiator cap or is it a problem somewhere else?
this cap is about 1 years old.
ive searched and no smoke from the exhaust or oil in coolant so im pretty sure my hg is ok.
what really stumps me is that it overheats with the cap on.. and it seems that one side of the radiator gets hotter with the cap on but with it off it seems even heat wise.
Old 07-31-2012, 08:29 PM
4Crawler's Avatar
Might want to put a pressure test gauge on the radiator and see if the system is holding pressure OK, if there is a high pressure leak or if the system is over pressuring from and exhaust gas leak into the cooling system. Might also have the radiator rodded out so see if it is partially clogged.
Old 08-01-2012, 04:58 PM
ignition's Avatar
hmm do you have to get a pressure tester at autozone? does this require pulling the rad?
dont think this rad is bad tho since it is brand new. it just seems that the cap isnt letting the coolant circulate while its on?
anyone ever hear something like this?
Old 08-01-2012, 05:13 PM
4Crawler's Avatar
Something like this:
- http://www.autozone.com/autozone/ino...tingAndCooling
How-to:
- http://www.cdxetextbook.com/engines/...gpressure.html
You could see if it is a pressure related thing, because there should be no significant pressure building in the system with the cap on until you start getting up over the boiling point. So you could see if it is "pressure rising then temperature rising" (not normal) or is it "temperature rising then pressure rising" (normal).
Old 08-01-2012, 06:03 PM
ignition's Avatar
thanks. i will be doing this tommorow and posting an update. hopefully this can tell me something..
Old 08-01-2012, 07:33 PM
Rerunn's Avatar
Try a new cap. If the cap isn't relieving the pressure then essentially the system becomes a pressure cooker.
Old 08-22-2012, 05:09 PM
ignition's Avatar
so im not able to find a pressure tested that in my radiator's neck size which was really wierd. they were all 1/2 inch wider at the neck. but i did buy a napa radiator cap to go with my napa radiator and now it slowly overheats when just idling but goes down when you give it gas/start moving.
is there still air in my system? i burped for at least 15 mins a couple times
Old 08-22-2012, 05:16 PM
4Crawler's Avatar
If it overheats sitting still, check out the fan clutch (if you have the stock setup):
- http://www.barneymc.com/toy_root/techneek/fan_clch.htm
That is what keeps air moving through the radiator when you are stopped. Maybe the clutch is not locking up, could be the bi-metal spring is not rotating the shaft in the middle. I found on mine I had to use a pair of pliers to free up that shaft as mine was sticking a bit. You can also put in a thicker silicone oil to make the clutch stiffer:
- http://www.4crawler.com/4x4/Docs/FanClutch.pdf
Old 08-22-2012, 05:26 PM
ignition's Avatar
hmm but wont the fan spin faster/slower based only on engine temp?
the engine temp is going down when i rev it at a stop and the fan clutch from what i read isnt affected by engine speed.. its something else no?
Old 08-22-2012, 05:36 PM
4Crawler's Avatar
Fan has a fluid filled clutch that has a bi-metal spring that turns a shaft that controls internal valving. It is supposed to sense the heat of the air coming through the radiator and as that temperature rises, the spring twists the shaft and that makes the internal valve close making the clutch stiffer. So if all is working right, the fan will pull less or more air at a given RPM depending on how cool or hot the air through the radiator is.
And with higher engine RPM, the clutch will spin faster, but the fan may or may not. When it is loose, the clutch pumps the silicone oil around inside and the fan has very little torque and moves very little air. As the spring turns the shaft, the valve closes down, making the clutch stiffer and thus the torque to the fan is higher and it'll spin faster and move more air at a given speed. In a vacuum, the fan would spin the engine speed, but in air, the faster the fan spins, the more air it moves and the more drag there is on it. So with a loose clutch, the fan spins slow and with a tight clutch, it spins faster.
Bit if the clutch fluid has leaked out or is too thin or the spring does not twist the shaft, the clutch is loose all the time, so never locks up and pulls lots of air. So you need to check and see if the fan actually moves sufficient air when stopped, can be done as noted on the link above, basically with a thin string to hold the fan still then see if it'll lock up and break the string or use a shop rag to see if you can stop the fan. It'll either be good or not, if not fix or replace, if good, it is something else.
Old 09-18-2012, 03:20 PM
ignition's Avatar
hey guys sorry for the late update but its been working perfectly now
lesson learned here is use the right radiator cap with the right radiator. had a huge headache with this because i thought oem cap would be fine on a napa radiator.
also toyota systems take a lot of effort to rid air of completely.
BIG THANKS for 4crawler and rerun for fast replies and a solution.
the1998sr5
15
07-14-2020 08:35 PM
Jeffreynmandy
07-18-2015 08:26 AM
the1998sr5
07-16-2015 06:20 AM
Avenged
07-09-2015 07:55 AM
Steezy96yota
07-06-2015 10:00 AM
Quick Reply: 2nd gen overheating problems
