2nd gen aftermarket door panel clear lens??
Was wondering if there's a company that replaces the OE red lens? I wanted to replace them with some clear ones if they do make. Anyone?
been looking myself and not finding any.
they are pretty simple, and thin.. I think that florescent lights covers you can buy at home depot can be shaped and molded to work..
the curve is very minimal, some light heat from a hair dryer, curve the light cover and drop into cold water to freeze/hold the bend and you should be able to make your own.
I will be trying it when I get to my interior fixes for the '95 Runner I just bought. It needs new carpet, dash cover, and some other interior fixes, this project will be one of them.
Yeah those aren't fo you to use as a light source outside the vehicle they're so people know to stop when your door is opeing in front of them.
Anyways try bicycle reflectors, I don't recall the size or shape of those door lamps. They have clear for the front and red for the back in various shapes and sizes.
"polycarbonate ("Tg" or "glass transition temperature")" I don't recall this exactly it's about 220-235 I think, the window between plastic and molten isn't very big be carefull. And let it cool down slowly or you'll get thermal shock and shatter or crack.
Yeah clear will look a little cleaner and match any interior. You can always throw a colored bulb or led in, and it won't look like a cycle or something coming up the road.
I'm abit over consious on the safety lights. Out here in the country we have had people run over due to mucked up lighting. Remeber to not let anyone stand in front of your hazard lights when you're on the side of the road changing a flat, and make sure they're flashing too!
I've been thinking about this lately too, maybe a sheet of acrylic, home depot has them pretty cheap, probably just cut to fit but won't reflect the light like a factory one.
06-01-2021 01:51 PM
jasonty
41
12-23-2018 01:00 PM
94yotaky
07-23-2015 07:50 AM
Steezy96yota
07-06-2015 10:00 AM
