2nd broken brake line
So a couple months back one of the rear metal brake lines (rear to drivers side drum)broke, it was a tiny leak but I got a replacement line bent up for it and fixed it. Today I was driving home and just as I'm getting home I feel the brake pedal go all the way to the floor. I get home look under the truck and the other rear metal brake line(rear to the pass side drum) is leaking.
So is this a common problem? Why do they keep rupturing? You would think the plastic ones blow before the metal ones
oh and i paid $70 for the other brake line to get bent up, should I go there again or is there another place I can get it cheaper?
Buy yourself a good quality double flaring tool (they generally have proper instructions with them), a small tube bender and a roll of 3/16 brake line from your local auto parts store and learn to make your own. It's not rocket science, you use the fittings of your old line (if they are still in good shape) or you can get replacements from your parts store and your use your old line as a pattern to make a new one. Another line at $70.00 and you will more than pay for the tools and materials that you need to make your own!
Factory brake lines might last 20 years in Ca., but anywhere where winter is harsh and they use salt or calcium on slippery roads you'll get 5 - 10 years out of brake and fuel lines. If you are lucky!
06-01-2021 01:51 PM
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
