| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
| Thread Tools | Search this Thread |
#76 (permalink) | |||||
#77 (permalink) |
Just make sure.... I only need rear coils right? No front coils?
#78 (permalink) |
yep, there is nothing but shocks in the front
![]() and IFS
#79 (permalink) |
does anyone know exactly what the 33x12.50s rub?
#80 (permalink) |
fender corners, i suppose
#81 (permalink) |
rubbing
Mine rubbed on the pinch weld of the inner fender and the firewall, unbolt and peel back the wheelwell liner and you'll see it. A couple hits with a hammer takes care of it. yours could be different though, put your truck in a situation where it rubs, pop it in park and jump out and check.
Derek |
#82 (permalink) |
ok will do... IF IT DONT FIT GET A BIGGER HAMMER !!!! =)
#83 (permalink) |
I'm assuming you will be lifting it some. You will need to trim the plastic valance under teh bumper some. You will rub on the swaybar while turning (if you still have the swaybar on there) and like others said, you will rub on the pinchweld. If you have your running boards still on, you will rub on the front of those.
FWIW, I haven't pounded my pinchweld yet, but my plastic fender liner is starting to take a beating.
__________________
Chris 7th Annual Pismo Jamboree: Sept. 25-27, 2009 '93 4runner SR5 3.0 Auto 4WD '07 Tacoma Dcab 4x4 TRD offroad '89 F250 4x4 w/utility bed M416 1/4 ton military trailer "Some people spend an entire lifetime wondering if they made a difference. The Marines don't have that problem." Ronald Reagan Semper Fi SLO 4wheelers |
#84 (permalink) |
just outta curiosity....what are you guys runnin 33's gettin for gas mileage?
#85 (permalink) | |
Quote:
This is the exact look I am going for Herculiner and all...now I know whose set up to copy
__________________
1994 4Runner SR5 3VZE (Auto) |DynoMax Cat-Back|-|EGR Block Off|-|31x10.5R15 Treadwright A/Ts|-|Infinity Reference and Kicker Components|-|OME Steering Stabilizer|-|Aisin Manual Hubs| |
#86 (permalink) |
^^thanx..
and the painted bottom is comon a few other guys on here have it, not sure who, but im sure you can find them |
#87 (permalink) |
Great Great Thread! Newbe here! I wish I would have read this thread a long time ago. Would have saved me some time. As far as rubbing, there is one thing I read about placing the spacers on the ball joints. That the tire could rub against the upper control arm. "Tires on rims with the stock backspacing of 4.75" might have tire rubbing issues with 31" or smaller tires." I plan on sticking to 31"s and buying some 16" or 17" stock wheels (take offs) for a newer model from a Toyota dealer. Just a heads up! here is the link: http://www.4crawler.com/4x4/ForSale/...ntSpacer.shtml
__________________
1993 V6 4WD Toyota 4Runner 203,000 Miles 50K on new gaskets Tacoma 17" Wheels 265/65/17 Stock Stance Corona, CA www.myspace.com/395rider www.youtube.com/kingofcrowntown |
#88 (permalink) |
First off let me explain that you do not need a lift kit to fit 33x10.50 or 33x12.50. the 10.50 will fit with no rub at all, while the 12.50 will fit with some rub, backspacing will help take care of that rub
example: ![]() ]So is this picture of a 4runner with no lift and 33x12.50's. how much rubbing is there? do you notice it with just daily driving or just when you're doing really tight turns? thanks Last edited by khamblin; 11-12-2008 at 06:00 PM. |
#89 (permalink) | |
Quote:
1" BL, bj spacers and Old Man Emu Coils with 33x12.50 BFGs. Minor rub on the pinch weld before bj spacers, I just ended up pounding the pinch weld and hitting it with some duplicolor bedliner paint to cover it up and protect it from rust. No rub now.
__________________
FOR SALE-95 4Runner 4x4 - 33x12.50 BFG's, Marlin Crawler Rear Bumper, Herculined Tailgate/Rocker Panels, All Chrome (Mirrors, Windshield Trim, Door Handles, License Plate Frame, and Grill) painted black, 1" 4Crawler Body Lift, 15x8 Cragar Wheels, 1 Regular Transmission Cooler (in-series with stock AT Cooler), Old Man Emu Rear Lift Coils, 4" Panhard Drop Bracket, Rear Pro Comp Shocks, BJ Spacers, Front SkyJacker Shocks, 1" Differential and Sway Bar Drop Kit FOR SALE-93 4Runner 4x4 |
#90 (permalink) |
on the phone with the junk yard hunting for fj80 coils man are they hard to get.......what else do you need to do when you put in the coils he wants $150 for the pair should i pick em up?
#91 (permalink) |
is it possible to get the specs on the rims of the very first pic in this thread? If anyone happens to know.
..this one for you lazy people. ![]()
#92 (permalink) |
thanks[/quote] This one has no lift and 33x12.50's. When i did my cruiser coil/ BJ spacer lift, with just the BJ spacers and no torsion bar lift it rubbed when turing fully. Instead of adjusting the torsion bars i beat and cut the pinch and eliminated rubbing. When I drive on the streets it does not rub, but when I start flexing and what not offroad it occasionally rubs but I don't find it to be much of a problem.
__________________
1995 Toyota 4Runner
Cruiser Coils, Bj Spacers, Aisin Manual Hubs, 4crawler Panhard Drop Bracket, Extended Rear Brake Line, Skyjacker Shocks, custom LSPV Bracket, 15x8 Cragar Soft 8's, 33x12.50x15 Mud King XT's, Marlin Crawler Rear Bumper |
#93 (permalink) |
Here is my 1995 4runner with BJ Spacers and cruiser coils
__________________
1995 Toyota 4Runner
#94 (permalink) |
Ever thought about taking the chrome trim off of the fenders, I think it would make the black on white look really good, either way i like your truck.
__________________
#95 (permalink) |
yea, the chrome is actually only on that side, i put it back on because when i grinded off the rust and bondoed that side, it came out a little rough on the fender edges. so i put the chrome on, but i plan on getting fender flares in the near future so...
__________________
1995 Toyota 4Runner
#96 (permalink) |
o ok, flares will look good
__________________
#97 (permalink) |
This isn't exactly "lift" but...I called Summit asking when my Eibach springs would be shipped since they were back ordered. Eibach is no longer making their 1.5" lift coils for the rear of '90 to '95 'Runners. If the Eibachs weren't listed, oh well, but they're not available anymore unless ya get 'em used. On another note, I found that H&R makes a set that's 1.5" as well, just fyi.
__________________
Jonny 1990 3.4 5spd 4Runner, 33" BFG KM2's 1983 5spd Shortbed, 35" BFG M/T's with no lift! Soon to be...who knows, but the 35's ain't stayin! "If at first you don't succeed, skydiving's not for you." -Unknown |
#98 (permalink) |
good to know
thanx |
#99 (permalink) | |||
Quote:
the only time it rubs is on the front inner fenderwell lip when i am seriously flexing the suspension at full turn on the trails. i have since hammered that lip down.
__________________
Olive Drab 1995 4WD regular cab pickup,22re, 33x10.5 BFGs,doetsch tech prerunner shocks, all pro shackles,sway bar delete. Quote:
Quote:
TREAD LIGHTLY |
#100 (permalink) |
so im looking at lifting just the rear...im going to use 80 coils springs and im going to need a panhard drop bracket correct???
what size lift would match in the front.. when i do s.a.s... 3inch spring over or a 5 inch spring over??? truck is trail only and am gonna run ifs and a raked rear.. for a while.. want a real flexy rear that will be ok when i get leafs up front... my 32 almost took out my stock bumper last trip so it needs to be done where as a s.a.s wants to be done... the stock ifs holds its own for now unmolested..
__________________
1991 HILUX SURF SSR-X turbo diesel right hand drive toyota imported in 2005 from japan, 130,000 km 31 bfg a/t auto current build 1987 LWB suzuki samurai. turning 2 into one.. yota axles welded front to back, yota springs , ifs steering box,, this bad boy will not only eat jeeps but toyotas aswell \m/ |
| Tags |
| 1990, 23585r16, 33x1250, 4runner, 92, bars, body, chrome, gen, inch, kits, landcruiser, lift, rims, torsion |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 3rd Gen. lift kit for 4runners | '98yotaLTD | Newbie Tech Section | 4 | 09-21-2007 05:53 AM |
| Attention all 2WD 4Runners with Sonoran Steel Lift. | cbr900boy | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 03-01-2007 10:08 AM |
| OEM lift 4runners in Colorado? | trollcruiser | 95.5-2004 Tacomas & 96-2002 4Runners | 9 | 04-30-2006 08:10 PM |
| 6 or 7 Inch Lift for 4Runners? | DuneRunner | Offroad Tech | 34 | 04-23-2005 07:13 PM |
| Anything bigger than 5" lift for 2nd Gen. 4Runners? | chazbizzle | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 04-13-2003 01:44 AM |
