22rte help!!!!!
Old 08-05-2012, 12:06 PM
toda90's Avatar
22rte help!!!!!
ok so trying to find this electrical issue is like pulling teeth. i am getting no fire at all but the pick up coil, coil, distributor, ignition control mod, distributor cap, and wires all check out. most of witch I've replaced and the truck still isn't getting fire. I'm at a loss with this truck. is there any thing I'm missing?
Old 08-05-2012, 12:12 PM
tampabayota's Avatar
check all your grounds
Old 08-05-2012, 12:25 PM
abecedarian's Avatar
When you turn the key "on", does the coil (+) and igniter module get power?
Old 08-05-2012, 10:43 PM
bob200587's Avatar
Take it to a trusted mechanic.
Old 08-06-2012, 03:31 PM
toda90's Avatar
Two of the wires going to the module are hit one isn't
Old 08-08-2012, 06:35 PM
"hit"... you mean "hot"?
I asked about the coil, but nevermind. So what module? The igniter?
Which two wires? Color codes please: there are several wires connected to the igniter.
Do you realise I was sitting in front of a wiring diagram for the truck while asking questions?
viesail
09-21-2015 06:00 AM
viesail
09-05-2015 04:23 AM
karbin
07-05-2015 11:37 PM
Quick Reply: 22rte help!!!!!
