22RE vs 22RTE...differences - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-21-2008, 11:31 AM   #1 (permalink)
Hayes's Avatar
Send a message via AIM to Hayes
Can anyone point me out to the major differences in the engine construction of the two?
I know the that Turbo has a lower compression ratio and forged internals, but are there any other differences?
I have thought about piecing together some parts to turbo my 85, so I have more power through the hills, and I am trying to gather as much information as I can.
Also, for the people who have 22RTE's, how does the Turbo affect the offroad capabilities? Do you boost when you are going fairly slowly, or just at the higher speeds?
__________________
Obama is an acronym.
OBAMA = One Big Ass Mistake, America
Hayes is offline
Old 11-21-2008, 12:06 PM   #2 (permalink)
AxleIke's Avatar
You boost at high RPM's, so, it doesn't matter what speed you are at.
It doesn't affect it at all. Just more power if you rev it up.
__________________
1987 Mutant 4runner.
-Lifts and Tires look cool at the Mall, Lockers and Gears look cool on the trail.
AxleIke is offline
Old 11-21-2008, 01:29 PM   #3 (permalink)
Hayes's Avatar
but do the rpms get high enough to cause boost when climbing rocks, or only when hill climbing and stuff?
__________________
Hayes is offline
Old 11-21-2008, 02:30 PM   #4 (permalink)
JamesD's Avatar
The pistons in the turbo engine are cast just like the N/A engines except they are lower compression.
James
__________________
New Tacome V6 transfer case http://www.yotatech.com/f107/sale-br.../#post50755569
Various Toyota truck/4Runner switches for sale http://www.yotatech.com/f109/various...trucks-148139/
JamesD is offline
Old 11-21-2008, 07:13 PM   #5 (permalink)
abecedarian's Avatar
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
cylinder head chambers are different (but heads can be interchanged)
pistons are dished on the 22rte (to lower compression)
oil passages in the block are slightly different, but they are not incompatible and there's a casting in the exhaust side of the block for the turbo oil return.
in general, the 22rte is below the 22re in power when revved less than around 2000 rpms, and provides around 50% more power than the 22re above 3000 rpms through redline.
as is the case with most turbos, the 22rte is, by design and such, not going to offer any more power from idle to low/mid RPM's than the 22re can, and at lower rpms may offer less power due to the lower compression ratio.
on the other hand, the 22rte design is quite capable of accomodating a supercharger which will compensate for the low-rpm doldrums (aka "turbo lag").
so now you have another option to consider.
__________________
Quote:
Originally Posted by DeathCougar View Post
Abe so far has been spot on, 100% correct. As usual
Insomnia: it's a way of life.
abecedarian is offline
Old 11-21-2008, 07:23 PM   #6 (permalink)
Hayes's Avatar
I have always considered a supercharger. I think I can piece together a turbo system for less. I only plan on about 6 pounds of boost, and since the 22re makes more power off the bat (against the 22rte without the turbo on), Lower boost can help me make more power on hills and the like. Basically, I am just thinking out loud.
Also, has anyone seen a centrifugal supercharger used on these engines?
__________________
Hayes is offline
Old 11-21-2008, 07:33 PM   #7 (permalink)
I feel you'll be in the realm of 'diminishing gains' if you try to turbo a 22re without significantly changing things, with regards to a 22rte in comparison.
In particular the fuel management. Rumor has it that the 22re can deal with approximately 3-5 psi boost without mods, however that also will require adjusting the timing (retarding it) to prevent significant detonation (since the 22re ECU is not programmed to deal with boost/timing requirements), which will put you almost on par with a 22rte with regards to 'off-idle' performance, and consequently will not provide the same peak power a 22rte would.
keep in mind the 22rte ECU is programmed with the turbo in mind, and the 22re ECU is not. So given the higher compression ratio in the 22re and having to retard the timing to prevent detonation, you end up in a "net-zero-gain" situation, where either one performs approximately as well as the other in most situations.
just a thought....
__________________
Old 11-21-2008, 07:41 PM   #8 (permalink)
Hayes's Avatar
I was thinking about tuning it with the MegaSquirt, which would allow for timing adjustments. I see what you are saying. A supercharger would be sweet, but with a high price tag.
__________________
Hayes is offline
Tags
22re, 22ret, 22rte, 22rte22re, block, compression, cylinder, differences, ecu, high, line, oil, passages, performance, pistons, return
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Megasquirt for 22re / 22rte dcg9381 The Classifieds GraveYard 0 01-06-2008 06:34 PM
Swap a 22RTE for a 22RE Teamsobaco 86-95 Trucks & 4Runners 8 08-19-2007 08:41 AM
22RTE to 22RE....how hard? Numbchux 86-95 Trucks & 4Runners 11 05-19-2007 10:26 PM
85 with 22RE, or 86 with 22RTE? CGuava 95.5-2004 Tacomas & 96-2002 4Runners 3 03-12-2003 02:27 PM
2009 InternetBrands, Inc.
